5 members (Donf, Woodcmiami, Jon G, 1955 1 Series, lumbersawyer), 115 guests, and 7 robots.
Topics128,269
Posts1,058,398
Members48,485
#164138 03/17/2006 4:55 PM
Just finished installing a new floor board in my '41 3/4 ton. Both the old some what rotted away original and the new replica have a 2 inch diameter hole at the center just in front of the seat base / gas tank enclosure. Anyone know what the hole is for??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#164139 03/17/2006 8:12 PM
I just checked my 42 which I'm still restoring and my floor has the same hole. Sorry I can't help but I can't find anything in my book about it either.
The crew that works on the \'42 --Sara, Hannah and Abby
#164140 03/17/2006 9:38 PM
Don't know about the earlier trucks, but the AD trucks have a hole in the driver's floorboard for access to the master cylinder that is mounted underneath the cab.
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#164141 03/17/2006 10:51 PM
I"ll second,
Master cylinder access.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#164142 03/18/2006 12:33 AM
And the vendors sell a rubber plug for that hole.
#164143 03/18/2006 2:27 AM
I’m asking more out of curiosity than anything, it seems an odd place for the hole to be It’s is not the hole for the master cylinder access, or the gearshift, or the emergency brake, or the battery..
#164144 03/18/2006 5:07 AM
It's for your finger. Stick it in to pull up the floorboard.
#164145 03/18/2006 2:05 PM
Far too practical, couldn’t be what it’s for.
#164146 04/06/2006 7:41 PM
so when you clean it out the water runs out
bill
#164147 04/07/2006 2:33 AM
Also far too practical, couldn’t be what it’s for
#164148 04/07/2006 6:04 PM
I don't know what it's for either. I just plugged it up. It just let's in hot/cold air.
George
#164149 05/18/2006 6:53 AM
Well,that must be what it's for! grin
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#164150 05/18/2006 11:41 AM
That's the ashtray!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#164151 05/18/2006 4:23 PM
how about for those long trips when you don't want to pull over at the rest stop...
1940 Chevy KC 1/2-Ton
#164152 05/18/2006 5:27 PM
Yup....the hole will work well for all of the above applications, My buddy even suggested it could be used for ice fishing. However I'm not convinced these are what Chevy had in mind.
#164153 05/18/2006 11:33 PM
Kip, it really was a lifting hole to remove the floor pan. No mechanincals below that would require an access hole. Like everything else on these trucks the simple answer is most often the correct one.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#164154 05/19/2006 3:15 AM
Maybe to pour your beer out when the red lights are flashing behind you.
#164155 05/19/2006 10:01 PM
So many practical answers. If I had to pick I would go with the lifting hole, the floor board is very difficult to get a good grip on from above.
#164156 06/08/2006 8:47 PM
master cylinder or lifting hole...
or maybe that's where you put the funnel for those long drives?
Another quality post.
Real Trucks Rattle
#164157 06/09/2006 12:58 AM
Former Workshop Owner
I thought that was for dropping bread crumbs, so you can find your way home.
(you are talking about the hole directly above the master cylinder, right?)
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#164158 06/26/2006 4:34 PM
The hole is not the one for the master cylinder cylinder, it is located exactly in the center of the floor board right behind the gear shift.
I have figured it out !!! The answer is ALL OF THE ABOVE.
However I did find a practical use for this "hole in the floor". Last night I drained what little lube oil was remaining in the transmission since the last time it was filled (probably 30 years ago) I found that a 3/4" hose will fit nicely into the transmission fill hole and extended it up through the "hole in the floor". I then placed a funnel in the top of the hose and wired the funnel to the "E" brake handle. Then proceeded to fill the transmission, no muss no fuss.
#164159 06/27/2006 12:43 PM
You have the right idea about the funnel & hose. On your truck you had a "long trip option". The funnel was only part of the option package. There was a tube (I believe it was bigger than 3/4") that was long enough to go from the funnel to the hole in the floor. It was used to avoid having to stop between fill ups. grin
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
Moderated by  ndkid275, Phak1
