BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,781 Posts1,039,298 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 2,031 | Has anyone used, bought, seen a roddoors in cab back panel? they are made of ABS, can be covered any way you want, they will fit over the 'in-cab' tank or they have a no-tank panel available. how do they look, fit? '47-`55* Rear Cab Cover - Smooth $189 '47-`55* Rear Cab Cover - Smooth -with tank $199 `47-`59 Chevy Gas Tank Cover `47-`59 Gas Tank Cover $199 http://www.roddoors.com/chevytruckdoors.html Look about the middle of the page.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | Joined: Mar 2005 Posts: 576 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 576 | have looked (drooled) over their products for the last several yrs. at the street rod nats in louisville. they have an ad cab on a dollie done up with their interior package. dont really remember the back panel by itself but remember the back aera being covered ,but was sure impressed with the whole package. seat sat fantastic.would love to have the extra funds to pull that one off......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | Joined: Jul 2004 Posts: 427 Shop Shark | Shop Shark Joined: Jul 2004 Posts: 427 | They do make the abs panel with or without the tank. Like david i'm hoping for the funds to do my 50. | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | http://community.webshots.com/user/46metal Carolines truck,click on the link above, then click on my photos. This is my first try at this sort of thing. 1. bard door skins 2. covered with pvc and test mounted on truck. 3. covered with closed cell foam then tweed material to match the kick panels and 4 back metal panel. I think it will look ok when I get finished. I wasn't hard at all. Beats Rod Doors price. Hope this works, as it's the first time trying this. lol | | | | Joined: Jul 2004 Posts: 427 Shop Shark | Shop Shark Joined: Jul 2004 Posts: 427 | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | wilbur, when the link opens click on My Photos, another link will open up and scroll down and click on Ed's 46 Chevy 1/2 Ton. I just checked and it works. Ed | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | wilbur, the reason no pictures are showing is because somehow when I registered with Webshots I'm showing my photos ad private. I'm trying to figure out how to change this.???? I tried to edit, but to no avail. Will keep working on it. I had a feeling I'd screw this up. lol Ed | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | wilbur, the link should work now. Let me know if it works and what you think. Thanks 46metal | | | | Joined: Jul 2004 Posts: 427 Shop Shark | Shop Shark Joined: Jul 2004 Posts: 427 | Yep works. I like it very much, Looks like it makes it easy to do.
Love the bolt! | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Thanks, It took me awhile to figure out how to make the panels, but after I got started it wasn't that hard. Still have a lot of work to do. | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 2,031 | the link does not work 46
| | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | Wrench Fetcher Joined: Jul 2004 Posts: 85 | carolines truck, I just tried the link again, and it's working fine. If you like pm me and I'll send you the pictures. Try it again and you should see Ed's 461/2 ton http://community.webshots.com/user/46metal | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | Shop Shark Joined: Jun 2005 Posts: 1,756 | I'm in the process of replacing the dang tar paper cab back now. Was going to use a fibre backed carpet pad once i get the old stuff off. Have a 62 with the tank moved and looking for somthing better looking. They don't show your idea for a 62. checking further, thanks. | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 2,031 | I now get the link many thanks 46
