3 members (55shaker, Bill Hanlon, 1 invisible), 76 guests, and 3 robots.
Topics128,037
Posts1,055,463
Members48,422
#164025 02/15/2006 1:35 PM
Apprentice
Apprentice
Is there a template for installing drivers side mirror arm ? I don't want to drill any extra holes in the new paint job. Is the round mirror the right one for my 1952. The PO had these massive rectangular things bolted on the door.
#164026 02/15/2006 2:55 PM
When I got round mirrors for both sides, they came with templates.
One piece of advice... while the mirror may be advertised as stainless steel, the screws are not. Put some kind of protective coating on them before they rust like mine did. And also put some heavy polish on the chrome arms - they get pitted easily!
Larry Bear
55.5 Chevy 3100 Panel
#164027 02/15/2006 4:03 PM
I don't know if your 52 is the same as a Task Force. But on Task Force doors, there are already mounting threads inside the door skin. You just have to locate them and drill the skin accordingly. Others may know this for sure, but it may be worth checking out.
#164028 02/15/2006 6:52 PM
AD mirrors are mounted to the cowl - the guide holes are already there - pick up the Accessory Installation Manual from any vendor for directions.
1954 GMC De Luxe COE
#164029 02/16/2006 3:17 AM
When I did mine, I had someone hold the mirrors in place while I sat in the driver's seat -- this is a great way of making sure you have them just where you want them!
Then I used the holes in the mirror-mounts themselves to mark the spots to drill ... placed masking tape down on the truck body and then drilled the holes.
It worked perfectly.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#164030 02/17/2006 3:11 PM
As GMCpanel has stated,
The Correct location on a 52 or Any AD truck for that matter is on the cowl.
And the Factory has put a Reinforcing metal plate,On Both Sides,thats already Pre drilled on the inside wink
Regards
#164031 02/18/2006 12:59 AM
Rusty,
The holes are there and you will want to hit them. You should also plan on puttin nuts on the inside of the cowl rather that relying on the sheet metal to hold the screws.
#164032 02/18/2006 2:57 PM
Apprentice
Apprentice
thanks for the help.The plate inside the cowl has 2 holes but they are alligned horizontally.Ive drilled through the cowl using the one hole that is in the correct location. But I can't access the lower bolt to put the lock washer and nut on. There is original sheet metal inside the cab covering the lower bolt hole. Will I have to access it through the upper hinge location?
Moderated by  ndkid275, Phak1
