| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 20 Apprentice | | Apprentice Joined: Sep 2005 Posts: 20 | Is there a template for installing drivers side mirror arm ? I don't want to drill any extra holes in the new paint job. Is the round mirror the right one for my 1952. The PO had these massive rectangular things bolted on the door. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | When I got round mirrors for both sides, they came with templates.
One piece of advice... while the mirror may be advertised as stainless steel, the screws are not. Put some kind of protective coating on them before they rust like mine did. And also put some heavy polish on the chrome arms - they get pitted easily! | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I don't know if your 52 is the same as a Task Force. But on Task Force doors, there are already mounting threads inside the door skin. You just have to locate them and drill the skin accordingly. Others may know this for sure, but it may be worth checking out. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | AD mirrors are mounted to the cowl - the guide holes are already there - pick up the Accessory Installation Manual from any vendor for directions. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | When I did mine, I had someone hold the mirrors in place while I sat in the driver's seat -- this is a great way of making sure you have them just where you want them!
Then I used the holes in the mirror-mounts themselves to mark the spots to drill ... placed masking tape down on the truck body and then drilled the holes.
It worked perfectly.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | As GMCpanel has stated, The Correct location on a 52 or Any AD truck for that matter is on the cowl. And the Factory has put a Reinforcing metal plate,On Both Sides,thats already Pre drilled on the inside Regards | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Rusty,
The holes are there and you will want to hit them. You should also plan on puttin nuts on the inside of the cowl rather that relying on the sheet metal to hold the screws. | | | | | Joined: Sep 2005 Posts: 20 Apprentice | | Apprentice Joined: Sep 2005 Posts: 20 | thanks for the help.The plate inside the cowl has 2 holes but they are alligned horizontally.Ive drilled through the cowl using the one hole that is in the correct location. But I can't access the lower bolt to put the lock washer and nut on. There is original sheet metal inside the cab covering the lower bolt hole. Will I have to access it through the upper hinge location? | | |
