| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Anybody have any trick for getting the rubber retainer in the groove around the headliner? It's prooving to be a beastly task! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | I had the upholstery shop install mine. I ended up helping the guy out as even he was having a time. Seem to remember a lot of grunts and groans and mutterings of lotsa foul things. Worth the cost to me in the end to have it done.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | What I did first was glue the headliner on to the roof with this glue sray from an airsiol can. Then you dont have to try and hold the headliner up while trying to install the rubber. Before I did that I was having a heck of a time.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I used a rubber mallet and a piece of wood. Take your time and move slowly.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ya mean getting the rubber groove on the metal lip! just hafta bend the rubber slightly to open the groove and work along a bit at a time - might use a small putty knife to help open it as you go
the ends of the rubber should be at the back, center, so just start there w/ one end and work around - if it wasn't a tight fit it wouldn't stay there - the only way is like highwayman sez, glue the headliner in first, then struggle calmly w/ the rubber and it will go
Bill | | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | I used alot of WD-40. You have to bend the rubber backwards to force into the groove. Bad thing is,using anything metalic to help push the rubber in and you run the risk of denting the sheetmetal on the roof, and it will show through on the top of the roof.
rebuild not replace
