3 members (Buckeye998, Stovebolt48, Hotrod Lincoln), 146 guests, and 1 robot.
Topics128,190
Posts1,057,339
Members48,469
#164019 02/14/2006 3:20 AM
V
V Offline
Anybody have any trick for getting the rubber retainer in the groove around the headliner? It's prooving to be a beastly task!
1959 3200 Apache Fleetside
In the Legacy Gallery
I had the upholstery shop install mine. I ended up helping the guy out as even he was having a time. Seem to remember a lot of grunts and groans and mutterings of lotsa foul things. Worth the cost to me in the end to have it done.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
What I did first was glue the headliner on to the roof with this glue sray from an airsiol can. Then you dont have to try and hold the headliner up while trying to install the rubber. Before I did that I was having a heck of a time.
38 original
48 panel
59 stepside
46 in the back forty
I used a rubber mallet and a piece of wood. Take your time and move slowly.
Dennis
ya mean getting the rubber groove on the metal lip! just hafta bend the rubber slightly to open the groove and work along a bit at a time - might use a small putty knife to help open it as you go
the ends of the rubber should be at the back, center, so just start there w/ one end and work around - if it wasn't a tight fit it wouldn't stay there - the only way is like highwayman sez, glue the headliner in first, then struggle calmly w/ the rubber and it will go
Junior Member
Junior Member
I used alot of WD-40. You have to bend the rubber backwards to force into the groove. Bad thing is,using anything metalic to help push the rubber in and you run the risk of denting the sheetmetal on the roof, and it will show through on the top of the roof.
rebuild not replace
Moderated by  ndkid275, Phak1
