2 members (walter74, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,675
#16394 01/17/2003 2:14 AM
Junior Member
Junior Member
All,
I have a 57 stepside with a 235 that is going to be replaced soon with a 283, out of a 63 Impala. I want to stay with the original starter and leave the kick start set up on the floor. My question is will that fly wheel work? If not what flywheel do I need (265) Can I use the one off my 235? Any help would be appreciated as the truck has only been with me a year, but I love it.
Willy 57
#16395 01/17/2003 8:05 AM
Welcome aboard Willy 57!
Pretty sure the flywheels won't interchange.
You might be able to use the starter switch from the 235 and adapt the mechanical linkage to the 283 starter though.
Would actually be pretty cool set up that way. Never occured to me to try that when I put a 350 in my '49 many years ago. I just put a starter button from NAPA under the dash!
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#16396 01/17/2003 3:47 PM
I doubt that the 283 ever came with a foot-mash starter, unless it was an option in a late '50s truck. You'll have to use a SBC flywheel with whatever starter you find. You may be able to put an electric switch for the starter on the floor to mimic the original linkage.
Also, the 235 bellhousing won't bolt to a V8, so you'll have to change bellhousings & transmissions.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
