1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16348 06/05/2004 12:14 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, This morning I picked up a SBC out of a '61 Apache, and here's some of the numbers i found. 3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4
Here's some more info on it. passenger side of block behind head (date manufactured): K172 Nov 1st 1972? Intake: 3927188 Intake date: 4188 Carb is a 2 barrel Rochester Distributor is points Passenger side of intake has a I think a heat riser of some sort just to the right of the carb on the intake. :confused: TIA, David
My truck don't leak oil, it just marks its teritory.
#16349 06/05/2004 12:35 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that block number is 68-76 truck and hi-perf 4bolt main 350, so was swapped into the 61 truck - the 'some sorta heat riser' is automatic choke mechanism - will have a bimetal coil in the sheetmetal box - intake and carb on an old motor can be anything a PO wanted - can't say about the rest
Bill | | |
#16350 06/05/2004 3:10 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Aha! Something I know something about. "Twin-4" block casting and stamping numbers. The 0010 block is one of the more common 350 blocks. The way to tell what is originally came in (it's been swapped into your truck) is to check the stamping code suffix on the pad at the front of the passenger side head. I wrote up some info on how to do that on this page. Good luck with it. | | |
