| | | Forums66 Topics128,130 Posts1,056,720 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I've had problem with fluid leaking onto my right foot (and the floor mat) ever since I had a master cylinder fail and replaced it.
I figgered the fluid was brake fluid leaking from the rear seal of the rebuilt M/C. So I replaced it and still had the problem.
Further investigation showed that it ain't brake fluid. It's oil. And it's coming from the area of the oil pressure gauge. I just discovered this yesterday while trying to get the fuel gauge working again (I found that the tan wire had broken and I'll be darned if I can find the other end of it.)
So...is the leak a common issue? Does the fitting just loosen up? Or is it more likely to be a problem with the gauge itself? I woulda done more investigating yesterday, but life got in the way.
Thanks, | | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Ray, I had exactly the same problem with my oil pressure gauge. Even after I tightened the fitting it would still drip. I then took the fitting off, put on some teflon tape, tightened her up and no more leak. You might want to give that a try. Don | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Thanks, Don. I'll give that a shot today and report back to ya.  | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I had the same problem last year. I was driving home from work, it was night time and I made a pitstop. Got out and had oil on my shoe and pants. With mine, it was the gauge itself. Developed a little crack that dripped nicely under pressure. I tried some epoxy and it worked for a few days, then started leaking again. I installed an aftermarket gauge temporarily. It's been over a year now and the temporary gauge is still hooked up. -David | | |
