4 members (Bill Hanlon, UtahYork, LAROKE, 1 invisible), 133 guests, and 3 robots.
Topics128,087
Posts1,056,377
Members48,442
#163107 06/09/2005 4:38 AM
Junior Member
Junior Member
When I bought the headliner for my 37 1 1/2 ton Chevy, information in the catalog indicated that it should be formed using water and ammonia. I have no idea what this process is all about. Can someone please enlighten me. The headliner is die cut and I assume that once it is shaped with the proper radius curves it will reasonably fit in place. I am concerned that it will crease if it is not softened prior to shaping. I would appreciate any help you can provide. Thanks, Ralph
I believe you spray the solution on the back side of the headliner in the areas that need to bend a little. Just spray enough to make it flex a little, not so much that your headliner breaks apart. Cecil........
Junior Member
Junior Member
Do you know the proportions for the ammonia water solution? Ralph
Junior Member
Junior Member
Just realized my last post may not be clear. What I am asking is the ratio of ammonia to be mixed with water. Thanks, Ralph
#163111 06/09/2005 10:50 PM
I will only guess that it's 50/50. Can't hurt, just try not to breath that stuff. It will open up your sinuses and make your eyes water. Cecil........
Also, get you something to bend it over, like a welding bottle or even a basket ball! It will take to to three people to get it in the truck, the more hands helping the easyer it is. Wet it down as much as you can with out getting the "good" side wet. Bend slow and easy, had some luck letting it dry out after a bend then wet the next area and bending it. You will find the rear corners are a compound bend and will require a good deal of work. Good luck, and let us know how you did. Joe
Junior Member
Junior Member
Well the headliner is done, not the best job but none the less it is behind me. First I tried 50/50, water and household ammonia. Thought I had it wet enough, tried to install it and realized it was still too stiff. Start over again next day. 50/50 water and household ammonia again. This time I thought for sure it was wet enough (as Joe said, those compound curves are tough) tried to install it and still not successful. Decided to see how wet (soft) I could get it by using a hose and letting water run on it for several minutes. Surprisingly, the running water must have removed the ammonia (the headliner was still damp from previous installation attempt) because the headliner actually became more rigid even though it was just short of being immersed in water. Next day I decided to try some higher concentration ammonia that I use for fuming wood. Might be 28%, it is used in making prints (paper, like blueprints). Again 50/50 but with the much stronger ammonia and headliner softened much sooner and to a greater degree allowing me to get it installed. Anyhow this wraps up my experience with fiber board headliners. Ralph
Glad you got done with out passing out! Thats good to know the ammonia worked. Must be something in the board that reacts to it??? I might try another one, I cheated and made a few cuts in mine. Joe
Junior Member
Junior Member
Is "CHEATING" allowed? LOL
Moderated by  ndkid275, Phak1
