| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | This glove box is eating me up!
Now that I know the geometry of how it supposed to fit inside the glove box cavity, how do you attach the thing?
I carefully removed the old screws and the spring "nuts" that the screws go into. I see how they attached the glove box but how did they get those spring "nuts" to stay in position while they screwed in the glove box screws? They were located on the underside of the lip and there is no way to get your finger in there to hold them while you rotate the screws.
Richie West
| | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Where are you at here in Cove?? I'm over off S116 By Martin Walker school. Maybe I could stop by and see if I could give you a hand with the box.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Richie, I messded up and deleted your message before I read it.Send it again if you would.
:mad:
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Are you talking about the small clip that acts as a catch when the glovebox door is closed? I used a pair of needlenose plyers to get that bugger in ... worked out easy enough.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | Horvath,
I am referring to those spring steel nuts that fit on the backside of the glove box mounting holes. The mounting screws go through the box then the metal lip and then must have a nut in order for the screw to tighten. These spring nuts have a hole large enough for the screw to fit and act as sheet metal nuts. There are 6 (three on top and three on the bottom) required to attach my glove box.
Richie West
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I don't know if it's "correct," but I found it much easier to slide the clips on the cardboard, then slip the cardboard outside the metal tabs in the dash opening and insert the screws. The spring clips can't twist out of the way if they're locked on the edge of the cardboard box; and you can gently press on the box to help line up the clips with the screw holes. | | | | | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | Hedgehog,
Like "duuuuuuuuuuuh". I used your technique and it worked great! Thank you.
Richie West
