2 members (WICruiser, Otto Skorzeny), 41 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#162863 11/08/2003 2:52 PM
Junior Member
Junior Member
This glove box is eating me up!
Now that I know the geometry of how it supposed to fit inside the glove box cavity, how do you attach the thing?
I carefully removed the old screws and the spring "nuts" that the screws go into. I see how they attached the glove box but how did they get those spring "nuts" to stay in position while they screwed in the glove box screws? They were located on the underside of the lip and there is no way to get your finger in there to hold them while you rotate the screws.
Richie West
#162864 11/09/2003 3:34 PM
Where are you at here in Cove?? I'm over off S116 By Martin Walker school. Maybe I could stop by and see if I could give you a hand with the box.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
#162865 11/11/2003 4:19 PM
Richie, I messded up and deleted your message before I read it.Send it again if you would.
:mad:
David
Just a firefighter,
'46 1/2 T Panel
#162866 11/12/2003 9:14 AM
Are you talking about the small clip that acts as a catch when the glovebox door is closed? I used a pair of needlenose plyers to get that bugger in ... worked out easy enough.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#162867 11/12/2003 1:09 PM
Junior Member
Junior Member
Horvath,
I am referring to those spring steel nuts that fit on the backside of the glove box mounting holes. The mounting screws go through the box then the metal lip and then must have a nut in order for the screw to tighten. These spring nuts have a hole large enough for the screw to fit and act as sheet metal nuts. There are 6 (three on top and three on the bottom) required to attach my glove box.
Richie West
#162868 11/12/2003 8:19 PM
I don't know if it's "correct," but I found it much easier to slide the clips on the cardboard, then slip the cardboard outside the metal tabs in the dash opening and insert the screws. The spring clips can't twist out of the way if they're locked on the edge of the cardboard box; and you can gently press on the box to help line up the clips with the screw holes.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#162869 11/16/2003 3:54 PM
Junior Member
Junior Member
Hedgehog,
Like "duuuuuuuuuuuh". I used your technique and it worked great! Thank you.
Richie West
Moderated by  ndkid275, Phak1
