11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Hi all, Has anybody used either one of these products under carpet? Im installing a rubber mat over carpet. Would extra sound deadeding be overkill?
Another thing is that I have 6 by 9's in the doors and they rattle pretty bad. Ive tryed spraying a few coats of that rubberized/asphalt undercoating inside the doors a week or so apart and it doesnt seem to be helping. any suggestions? Thanks in advance Justin | | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I wonder if your rattle might be the speaker mounting. Putting some rubber grommets or rubber gasket between the speaker and the mounting area could fix this problem.
If this isn't the source of the rattle, it might be the window and other components rattling from the speaker vibration.
I put the asphalt-based mat (Q-Mat I think was the name) on the floor area over the transmission hump from front to rear. This really reduced the drivetrain noise considerably. | | | | | Joined: Apr 2005 Posts: 36 New Guy | | New Guy Joined: Apr 2005 Posts: 36 | make sure your doors have good seals with a heavy plastic as well. like on the new cars. as far as floor you can either get some sound deadener or even some cheap carpet with a rubber backing and putthat under the finished carpet
DustyG.
1952 Chevy 1.5 ton 1949 Gmc 2 ton flatbed Dump
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | look at alan horvath's site. he has some very good suggestions. i used waterheater insulation with the foil backing it is a lot cheaper than the commercial stuff. you can use quick roof patching material from the home improvement stores. another product is peel and seal. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Thanks for the replys guys, The speakers are mounted inside of a foam enclosure that shares the speaker mounting holes. I am redoing the window felt/guides and catwiskers so im sure that'll make a difference as well. I was thinking of trying some polyester filling kinda like the stuff they use in sleeping bags to fill in the big empty space inside the doors.
On the floors and firewall I got a lot of real nice scrap carpeting for the right price (FREE!) So Im figuring Ill use that and maybe put "fatmat" underneith. It is pretty inexpensive about 60 bucks for 50 square feet or something. Only thing is I cant use it inside the doors after spraying on that "sound deadener" | | | | | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | We B, Do you have a link to that site? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | www.alanhorvath.com then go to the bottom of the page and click on alan's ride. ron
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | GREENGUY, another site you might want to look at is www.chuckthetruck.com
| | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Greenguy I used peel and seal roofing product. it is a modified bituim with a aluminium foil face. It is about 60 bucks for a 100 sq ft roll. This will stop druming. Over top of this i put a insulating product that is a double layer of bubble wrap with foil on both sides. I think it should work quite well | | | | | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | We B, Thanks for those links. That guy Alan H has a real nice sight. The pics are awesome and has some good pointers. I'll be cruisin down to "Home Desprate" later on this week. Thanks again gents | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | HERE\'S the link to that page on my site.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Apr 2005 Posts: 3 Junior Member | | Junior Member Joined: Apr 2005 Posts: 3 | the Alanhorvath site has some great info. Has any body used spray foam in any of the cavities in the cab. There are a lot of closed areas in a cab and I was thinking to drill a hole in the cavities and fill with foam.
gene holland 57 swb 59 Lwb
dutch57
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | that couldn't hurt, just make sure to seal up the hole you drilled.
2003 ford lightning 1959 chevy 36
