1 members (1955 1 Series),
113
Mod | | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I have a 55.1 which currently has single seats in it. I would like to go to a bench seat so my wife, daughter and I could all go for a ride.
What bench seats would you recommend?
Thanks, Chris
Chris 1955FirstSeries
| | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Chris, the stock bench is good. You know they fit... And they always look at home in there!
Christian | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I like the looks of the stock seat, but for comfort I really like the '48 Chevy sedan front seat in the '51 right now. Nice and cushiony, deeply padded. And the brown roll and pleat naugahyde doesn't hurt either!! It was an easy install, and all of the modifications were made to the seat, not the truck. Of course, I don't know how easy it would be to find a seat like that in your part of the country.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i looking to put a buick lesabre 60/40 bench with console and integrated seat belts it will fit but i have not found one yet. on my list for this year it also electric. another .02 ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | My truck has a split bench seat from a late-70s/early 80s Monte Carlo ... I want to put single seats in, with a console this summer, but the Monte Carlo bench is nice!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Thanks for all the suggestions. I am sitting on the fence as to stock or modern.
-Chris
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | That fence is probably pretty uncomfortable Chris. If you have moved the gas tank out of the cab then a modern set that folds forward will provide access to that new storage area. If your tank is still there and you have plans to leave it then the stock seat is a good choice but if the mounting frame has been removed for your buckets then you will have a challenge getting it mounted.
The modern buick seat is a good choice but it does not fold forward. The Monte Carlo (G-body) bench is a good choice and can be found pretty easily. Another option is the ford ranger bench seat. Any seat that is 55 inches wide can probably be made to work.
A modern seat may sit too low and may require you to fabricate a riser to attach it to the floor. I would also suggest you run a strip of steel under the cab floor to reinforce the seat to cab bolted connection. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | That's it. I have decided the stock seat is the way to go.
Thanks gang.
-Chris
| | | | | Joined: Sep 2002 Posts: 7 Junior Member | | Junior Member Joined: Sep 2002 Posts: 7 | I have stock seat in my 54 but made a small mod to my back cushion to make it fold forward. Break off the three stakes that go down into the pockets at the bottom of the rear seat cushion.They will break off easily at the first spot welds leaving a nice flat area to drill holes for mounting new pieces. Replace ( by bolting in) three strips 9One for each pocket) of 1 inch by 1/8 by 8 inch long steel strips. The strips actuall replace the original stakes and make them longer. Bend the strips as a radius and make a sharp bend on the end like a claw. The strips will go down into the pockets just like before except they now go alot deeper. When the seats rocks forward the strips stay totally in the pockets and the claw end acts as a stop from pullin them out. The upper mounts are still used except I re tapped and use thumb screws for easy removal. Make sure the top loops fit good and snug as they go over the pipe frame. This gives a good tight feel as you slam her back into back position. The seat easily folds forward and I built a shelf on top of my stock gas tank and have gained tons of great storage. A side benefit, you can also put a dog leg bend at the top of the strips and actual reset the angle of the seat to be less straight up and down. I did this and my back enjoys the new angle alot better. This is an easy project with great rewards as well as keeping her stock. I will share photos if someone is interested | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Great info..would love to see some pics of that [email protected] a lot | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | hartmte, could you post pictures or have someome do it for you? i am not very good at abstracts. your project sounds the way to go. i have ordered a new tank for under the bed and would like to make use of the space to end the clutter on the floor of the truck..ron
| | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Sounds a neat trick hartmte. Like shooper I'd love to see pics as I might go that route with my 54. Christian | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Pics, send me some pics and I can post them. It sounds like a great mod.
Thanks, Chris
| | | | | Joined: Sep 2002 Posts: 7 Junior Member | | Junior Member Joined: Sep 2002 Posts: 7 | I will send pics to Chris 1955FirstSeries, he will post, I could not figure out how to attach pics to a post. | | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Many thanks for the pic hosting Chris. Yup, that's a really nifty way to make some much-needed storage, Hartmte. Elegant simplicity. Nice job. And good to be able to stash stuff out of sight when parked. Or maybe I'll make it a bookshelf so I can pick out something to read when I'm waiting for my wife--she usually runs late :~)... Christian | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | hartmte, great pictures!!!!!! recieved email and read the post also. thanks ron
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | That's a sweet setup! Very creative. Looks like a good project for this weekend. Thanks for sharing. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i started on the seats yeaterday the only metal strips i could find was at tractor supply and they were 3/16 not 1/8 works but a little harder to bend. i tried heat but i only have a butane torch. still lke the results so far. thanks for the pictures i would have been lost without them. ron
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 |
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | WOW!!!! slick idea. gotta save that for reference for my '54 pick-up. Marty | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | old post but good idea about extra seat storage. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
