3 members (WICruiser, Charles in CA, Otto Skorzeny), 37 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#162237 11/05/2003 11:15 PM
Bondo Artiste
Bondo Artiste
I have been looking at those nice original style arm rests that most of our favorite part suppliers offer and I am wondering how hard is it to install them, and are they nice and sturdy?Just curious......
~ Phillip
#162238 11/06/2003 6:44 AM
Assuming you still have the thread blocks in the door, it's as simple as righty-tighty. Save yourself some grief and order the correct mounting screws at the same time. As for structure, it's a hunk of plastic with a honeycomb interior. By design, they take a downward force better than a pull, and I wouldn't hang from one. You can use it as a door pull if your doors are aligned and latch easily, but I have seen many break around the mounting screw from slamming the door.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#162239 11/06/2003 10:43 AM
The trick to making them last a long time is pull the door closed but stop pulling when the door slams shut grin
Seriously, pull on the handle to get the door moving but let off on the pull as the door comes closed. (just like a quarter-mile race, HAMMER ON and let off grin )
Like Hedgehog says, keep the latches and hinges adjusted and like I say, don`t use the arm-rest door pull to pull the door THROUGH the door opening eek grin
#162240 11/06/2003 2:33 PM
Phillip,
My sets came from either Jim Carter's and Chevy Duty. One set came with an installation template and a set of very sturdy screws (I think Chevy Duty).
If your hinges and latches are good and your door is hung properly (big ifs), and if people follow Mechainiac's closing instructions, the arm rests are quite sturdy.
Tim
Moderated by  ndkid275, Phak1
