0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#162185 08/04/2003 12:41 PM
My '51 3100 came in boxes.. having some trouble re-assembling. I got choke & throttle cable in ok, but have another knob without any letter on it...could this be the cable for defroster? Also, can anyone advise where the heater motor should pick up its power, and at what amperage it is suppossed to be fused? Thanks!
#162186 08/04/2003 10:53 PM
The push/pull cable might go to the control valve which cuts the flow of coolant to the heater core.
My heater was devoid of wiring, so I just ran a feed off the ignition through a 20A fuse, and to the fan switch (this is a 12v conversion, I have no clue what the stock heater's resistance threshhold is). I'm sure there are 'bolters who can give you an idea of the factory wiring configuration.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#162187 08/05/2003 5:07 AM
Anonymous
Unregistered
Anonymous
Unregistered
That extra cable goes to the defroster flap. The heater motor is supposed to gets its hot from the ignition switch [ but I like to hook it up to the constant hot terminal of the headlight switch [ cause it has a built in thermal switch ].
10 amp fuse is fine for the blower motor.
#162188 08/05/2003 4:23 PM
OK, thanks...I'll hook up extra cable to heater defroster flap..cable seems too long though, i have it mounted in holes under radio near center of dash...does it maybe go further away? I'll just make up some wiring for the heater with an inline fuse holder. Thanks guys.
#162189 08/11/2003 2:38 AM
Actually, that control was mounted on the left side, below the headlight switch. The electrical switch to control the blower motor was right beside it. If you get a hold of the accessory installation manual, you will see nice drawings of all the hookups and such.
#162190 08/11/2003 1:43 PM
Thanks Brian, I haven't run the wires yet, so i moved the controls per your reply. - Jim Smith
Moderated by  ndkid275, Phak1
