2 members (TUTS 59, klhansen),
71
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Need help on the procedure for forming a cardboard headliner. Vendor ads indicate "form using amonia and water" Can one of you explain? Thanks, Ralph | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | No one steped in to help so here's my take. I didn't use anything on mine, but it is a bear if you have the floating type headliner. It will take two people! Try to take your time so that you don't put a bunch of creases in it. A solution of 50-50 water and amonia is sprayed on the backside so that it gives flex to the headliner. Don't overspray and get it soaked. Most people recommend that you put the front section in first, but it's not mandatory. Good luck and go the the search section of the forum and type in headliner. You'll get more info. Cecil.......... | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Cecil, thanks for your reply. Ralph | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I have a two piece floating headliner. I ordered mine from Chevy Duty I believe. It took two of us to install and I don't think I could have done it with out the extra set of hands. We took our time and I only have one small crease line that I can see. Otherwise it came out smooth as can be.
Good Luck, Chris
Chris 1955FirstSeries
