3 members (55shaker, Jon G, BillCollins), 113 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#162085 12/24/2004 1:49 AM
Junior Member
Junior Member
Need help on the procedure for forming a cardboard headliner. Vendor ads indicate "form using amonia and water" Can one of you explain? Thanks, Ralph
#162086 12/25/2004 3:52 AM
No one steped in to help so here's my take.
I didn't use anything on mine, but it is a
bear if you have the floating type headliner. It will take two people! Try to take your time
so that you don't put a bunch of creases in it.
A solution of 50-50 water and amonia is sprayed
on the backside so that it gives flex to the
headliner. Don't overspray and get it soaked.
Most people recommend that you put the front
section in first, but it's not mandatory.
Good luck and go the the search section of the
forum and type in headliner. You'll get more
info. Cecil..........
#162087 12/27/2004 8:11 PM
Junior Member
Junior Member
Cecil, thanks for your reply. Ralph
#162088 12/28/2004 4:38 PM
I have a two piece floating headliner. I ordered mine from Chevy Duty I believe. It took two of us to install and I don't think I could have done it with out the extra set of hands. We took our time and I only have one small crease line that I can see. Otherwise it came out smooth as can be.
Good Luck,
Chris
Chris 1955FirstSeries
Moderated by  ndkid275, Phak1
