4 members (Phak1, Bullriders, Greg_H, 1 invisible), 35 guests, and 0 robots.
Topics128,089
Posts1,056,009
Members48,430
#162018 11/04/2004 7:14 PM
7
Junior Member
Junior Member
7 Offline
I have a '71 chevy truck. The steel door panels are in very good shape overall. Does anyone know how to replace the Chrome film tape that has peeled off? I see a lot of these trucks running around showing the grey trim beneath the missing tape. I dont want to spend the money to replace the door panels if there is a reasonable fix. Thanks :confused:
#162019 11/05/2004 12:32 AM
Try going to a trim shop and see if they can modify a stripe or a molding to work.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
7
Junior Member
Junior Member
7 Offline
solution= I found that working aluminum duct tape over the peeled plastic molding worked. I cut full lenght over width strips and maticulously worked each strip on. Once applied I used a razor knife to trim. Surface needs to be extra clean. If I knew how to post pics without a host I would. I am impressed of the results.
check out a body shop,you can buy a roll of door edge trim.this my help ya out.auto parts also
dan-pa
Moderated by  ndkid275, Phak1
