2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 18 Junior Member | | Junior Member Joined: Oct 2004 Posts: 18 | I have a '71 chevy truck. The steel door panels are in very good shape overall. Does anyone know how to replace the Chrome film tape that has peeled off? I see a lot of these trucks running around showing the grey trim beneath the missing tape. I dont want to spend the money to replace the door panels if there is a reasonable fix. Thanks :confused: | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Try going to a trim shop and see if they can modify a stripe or a molding to work. Just a thought, Scott | | | | | Joined: Oct 2004 Posts: 18 Junior Member | | Junior Member Joined: Oct 2004 Posts: 18 | solution= I found that working aluminum duct tape over the peeled plastic molding worked. I cut full lenght over width strips and maticulously worked each strip on. Once applied I used a razor knife to trim. Surface needs to be extra clean. If I knew how to post pics without a host I would. I am impressed of the results. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | check out a body shop,you can buy a roll of door edge trim.this my help ya out.auto parts also
dan-pa
