1 members (52hornsby), 86 guests, and 0 robots.
Topics128,049
Posts1,055,680
#161667 01/14/2004 12:14 AM
Junior Member
Junior Member
How do you adjust a bench seat in a 50 3100? Awhile back I removed the entire interior, now that it's going back together I can't figure out the seat adjuster cable mechanism/proper set-up/magic words....Any guidance would be appreciated :confused:
#161668 01/16/2004 2:46 PM
Did it have a cable that wrapped around a roller on each side, and then go back and forth through a small passage at the back end of the seat? Sometime around there it changed to a different way of adjusting.
#161669 01/17/2004 1:35 AM
Junior Member
Junior Member
I think the cable is routed correctly (?) when I move the lever and try to move the seat only the drivers side works, if the spousal unit assists, the passenger side will move but won't lock in the forward position....darned new fangled @#$^!
#161670 01/17/2004 3:02 PM
OK, but you really did not answer my question. I will assume you have the cable routed around the back. Take off the seat cushion. Is the cable clamped down on both sides to a piece of the seat frame? If not, that is your problem. If it is, I advise pulling up the frame and removing the cable, take it to home depot and make a nice new one, make sure it is the EXACT same size as the old one. Clean and lube all the rollers and reinstall the new cable. Be sure the cable crosses itself on its journey from one side to the other. That is very important. Also - are the 2 springs still in place?
#161671 01/20/2004 8:08 PM
I sent some seat cable photos directly to Geoff. If others need them, I can upload them to the web. Let me know if that would be helpful.
#161672 03/07/2004 2:09 PM
I think this will help me too. Thanks for the great details.
1951 1 Ton Completed
#161673 03/08/2004 9:50 PM
By all means, my good man: POST!
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#161674 03/09/2004 2:43 AM
My cable was rusted apart from the mouse pee so a picture on how it's run would be very nice, 51. Does anyone know what the exact length of the cable should be?
#161675 03/09/2004 4:27 AM
I will post some images as soon as I figure out why my StarPhoto page is not loading. Sorry for the delay.
#161676 03/10/2004 7:25 AM
10:22 PM PST Tuesday-
Starphoto is freakin' finally running again. grin
Bench seat cable photos
Knock yourselves out!
#161677 03/10/2004 6:27 PM
Posted bench seat cable photos last night, but the site is back to running slow or not at all this morning (9:25AM PST/12:25 PM EST). Grrr! :mad: eek :mad:
#161678 03/12/2004 1:40 AM
Stovebolters to the rescue. ChevyAsylum has graciously offered web space for the shots of the bench seat cables. Stop by 51Phatboy Seats to see the images of the cables on the 1947-54.5 bench seat I am rebuilding. Hope this helps you folks putting them back together. I do not have a full length measurement to share.
Three cheers for Ray! wink :p cool
#161679 03/12/2004 5:47 AM
My pleasure PhatBoy. Glad to be of service.
Moderated by  ndkid275, Phak1
