3 members (Nick in Manitou, Hotrod Lincoln, TUTS 59), 123 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#161615 05/05/2004 4:42 PM
Okay,
I will be pulling my steering column and seats this weekend. When strategizing last night it looked like at one point that there was a cover at one time that went over the gas tank behind my seats.
Are gas tank covers made or will this be something I need to fabricate?
Chris
Chris 1955FirstSeries
#161616 05/05/2004 5:32 PM
Anonymous
Unregistered
Anonymous
Unregistered
I cannot see in the assembly manual where a cover existed originally behind the seat but I do know that one is available aftermarket but it is more for street rod applications. I think Rod Doors supplies one. If you are using the stock seat though it may not matter as you can't get back there anyway. If you have a non-original seating setup then a cover would be the ticket if you have the tank located in the cab still.
#161617 05/05/2004 5:44 PM
Thank Houston54,
My truck is a streetrod, all original except for the 283, steering column and seats. I am putting in late 90's s-10 bench later this weekend and I will search for the aftermarket cover.
Chris
#161618 05/05/2004 5:56 PM
Anonymous
Unregistered
Anonymous
Unregistered
Go to Roddoors.com. They have it for $179. If you have removed the tank as I have this opens up scads of storage space but their cover will not work well in that situation. I plan to insulation and cover with short pile carpet up the back to the belt line. Send me some pics when you get the seat in. I have not decided which way to go on that subject yet.
Good Luck
#161619 05/07/2004 5:59 AM
Junior Member
Junior Member
Roddoors has two types of covers. One for the original in-cab tank and one for the aftermarket swaps.
Moderated by  ndkid275, Phak1
