2 members (RLB, Patina 54), 98 guests, and 1 robot.
Topics128,136
Posts1,056,426
Members48,441
#161607 02/26/2004 9:42 PM
Hey guys
I have a strange question I hope I can discribe it correctly. I have a 49 chevy 5 window and on the inside of the cab around the doors there is suppost to be a wind lace (atleast I think thats what they call it) I have removed it and only the track is left. I was wondering if I can remove that track and not put the rubber back maybe upolster over or something like that I think the rubber is very ugly and I would like to get rid of it. Has anyone done this and if so what did you do?
Chris
the windlace on my *late 49 (has a track that the windlace goes into, not sandwiched by a paice of steel and screws) doesnt even hit the door on 50% of it, so i dont think it will matter.
The seal on the door itself does all the sealing (on mine anyway)
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
I bought a new windlace for both doors on my truck. When I do the interior, I'm gonna cover the new rubber with vinyl.
I think it helps keep a seal around the door ... noise and wind-noise ... at least that's what they're intended to do.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Thanks everyone,
I think I am going to take the rails off and upolster over the areas. I dont like the look of the rubber if I have to I think I will put some rubber around the door itself. But if anyone else has a different idea please let me know I am open for suggestions.
Thanks again
Chris
Z
Z Offline
Try to salvage some of the channel, it's not available any more and I need some that goes down the front edge. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
I have thought of the same thing on a '51..however i wondered how to trim the edge. The rubber holds the covering..i will be watching this post..if you come up with an idea please post it here.
On the same note, I have a 52 cab that is just as you have described it: a channel with rubber in it around the doors. But I have a 48 cab that has a flat painted piece of trim that goes around the doors. Is this factory? I need some replacement. Where can i get it?
Rob Mathis
48 Half Ton with 235 & SM420
http://community.webshots.com/photo/189861216/291883405ujzIZz
You can get the cab windlace at Chevy Duty or Jim Carters is you want to stay stock. Cecil....
Moderated by  ndkid275, Phak1
