Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (KEVINSKI, frogfarmer, baldeagle, TexasFarmTruck, 1 invisible), 177 guests, and 6 robots.
Topics128,282
Posts1,058,632
Members48,492
#1615551 11/18/2026 4:33 PM
Anyone know the difference in brake lines between a 1/2 to and a 3/4 ton long bed?
Is it because the frames are different?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #1615555 11/18/2026 5:32 PM
7
7 Online: Content
My '57 uses 1/4 inch for the entire truck, no change in diameter at any of the joints. I just used a 25 foot roll of nickel-copper and new rubber hoses where called for.
jmoore #1615578 11/19/2026 2:43 PM
Thanks.
I was looking to buy a set for the 3/4 ton, but none that I can find for a 57. Just all years before and after or 1/2 ton lines for 1957.
1957 GMC 150
jmoore #1615589 11/19/2026 11:28 PM
7
7 Online: Content
Do you have any existing hard lines at this point? Each component such as the master cylinder, wheel cylinder, etc. will be a specific size thread and nut diameter. That will dictate the steel tubing diameter. The copper-nickel line is easy to work with, my truck has a 15 foot bed and a Low Cab Forward, it took all of the 25 foot roll.
