| | | Forums66 Topics128,282 Posts1,058,621 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 567 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 567 | Anyone know the difference in brake lines between a 1/2 to and a 3/4 ton long bed? Is it because the frames are different?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2016 Posts: 2,014 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,014 | My '57 uses 1/4 inch for the entire truck, no change in diameter at any of the joints. I just used a 25 foot roll of nickel-copper and new rubber hoses where called for.
| | | | | Joined: Jun 2003 Posts: 567 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 567 | Thanks. I was looking to buy a set for the 3/4 ton, but none that I can find for a 57. Just all years before and after or 1/2 ton lines for 1957.
1957 GMC 150
