Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Wally / Montana, RaNfLaS), 136 guests, and 4 robots.
Topics128,282
Posts1,058,621
Members48,492
Page 2 of 2 1 2
I
I Offline
Originally Posted by Gdads51
Love the progress and will celebrate with you from afar. Neat to continue the "Moon Eyes" theme inside to the shifter handle. thumbs_up
Thanks, Dan! Your shared enthusiasm is much appreciated.
I did want to continue the Mooneyes theme, but also wanted to keep it a bit subdued, hence going for the black ball with the eyes, rather than their standard yellow.
Plus, it feels better in the hand than did the motorcyclist skull knob.
~~ Konstantine
1962 Grumman Olson Kurbside/Chevy P30
Follow in the DITY
I
I Offline
Originally Posted by Otto Skorzeny
Konstantine, take a look at this shift boot in another thread. I think it might be a better choice than the round peg in the square hole situation you have now.
https://www.stovebolt.com/ubbthread...5167/floor-mats-for-4-speeds#Post1615167
Hi Otto.
Thanks for that link. Interesting. The boot I put on is a direct replacement of what came off the vehicle, so I assumed it was the correct boot for it. It even had cutouts underneath for the mounting studs to sit in.
I'm wondering now if what was on there was an incorrect replacement at some point in its life?
~~ Konstantine
Follow in the DITY
Prolly the only boot the previous owner could find at the time. Grumman surely wouldn't have let the vehicle out of the factory with such a jerry-rigged shifter boot that doesn't cover the hole in the floor.
The round boot may have been the one used for a different application, like a pickup truck or something.
1950 Chevrolet 3100 (Ol' Roy)
I
I Offline
Ah, I see.
My chassis, motor and drivetrain are a Chevy P30, so that may be why.
This boot was the one listed for my vehicle on the Mill Supply site. I'll keep the link you send me in mind. Thanks very much.
~~ Konstantine
Follow in the DITY
I
I Offline
Well, the plan yesterday was to install a new GM style headlight switch to replace the off-the-shelf two position headlight switch I have but, as with many well-laid plans, I realized that was missing some components so I had to pick another direction.
What I ended up doing was finally painting the heater box and blower box for the interior of the Grumman. I had purchased some gold metal flake paint quite some time ago, but ended up having to work on more essential things until now. The nice thing about being able to paint means I'm actually closer to done with the essentials and can focus more on the smaller and more fun bits!
The first pick is of the vertical defroster vent which I painted last year in flat black. That's going to stay that color.
The other photos are of the gold metal flake paint I used with a 2K clear I bought from Kustom Canz. I like the quality of the product. It sprayed well, other than every once in awhile the tops were spitting, but it was manageable.
One can of their black base coat was more than enough for the two pieces given that I had also primered them in the same color. One can of gold flake was emptied getting the results you see in the pics on the two pieces. I'm happy with the results and will say the pictures don't do them justice.
Hopefully, next week I'll be able to install them and keep moving forward!
Vertical defroster vent
Heater and blower box prep
Final paint
Final paint
Final paint
Final paint
Final paint
Mad Scientist
Kustom Canz
~~ Konstantine
Follow in the DITY
Looks like they turned out great Kon! thumbs_up
~ Dan
1951 Chevy 3 window 3100
I
I Offline
Thank you! It's slowly coming together.
~~ Konstantine
Follow in the DITY
I
I Offline
Thanks to all involved with suggesting and moving my thread to DITY. I am honored and happy to be here
Tuesday was another momentous day for me and the Grumman.
Four + years ago, I took the heater core and blower out, and removed the internal defroster vent and heater boxes because everything needed to be repaired and/or cleaned and painted. I kept them out all this time because it made fixing everything in the engine bay and running new wiring much easier.
I had the heater core repaired thanks to Mr. Louie Lamb in Los Lunas! He's the only radiator rebuolder I know around here. A lost art. When he repaired the heater core, he removed the non functioning bleed and said they tend to leak, so he soldered a penny y over the hole.
I then brazed the various cracks, and brazed new tabs on the heater boxes and heater core mount, then painted the defroster vent , heater core and mount, and fan with high heat flat black, and the heater boxes with gold metal flake paint. Also, I used some rubber pipe wrap to fill in the gaps around the perimeter of the heater core. I had wondered what to use, and this seemed a good choice as it is flexible enough to compress and shove into tight spaces, will expand into the larger spaces, and it's rated for a bit over 210+ degrees Fahrenheit.
The reason it was momentous is because I had decided not to reinstall everything until I got the Grumman set up, and running right. Yesterday was install day, which means it's set up and running right!!!! Can you tell that that makes me happy?
A HUGE thank you to my bud Brad for coming over that night to help me with the install! I couldn't have done it without his help. We were working in the dark, with flashlights. It is a two person job as someone has to support the heater core and insert the mounting bolts from the cabin side, while a second person is needed to install and tighten the nuts from the front of the vehicle, through the access door.
There was a moment of synchronicity in all this for me. When I reinstalled the badge on the heater box, I saw that the body was made in Athens, NY. That's funny in a couple of ways. First, I used to live in Athens, Greece, and when I retire in a few years I plan on moving back and bringing the Grumman with me. Second, I'm originally from NY. So, it seems the Grumman combines two major points of my life. No wonder I feel so connected to it. 😀
That's it for this installment. Next, I'll be buying the appropriate hoses to plumb the heater core, a manual shut off valve to put inline with the feed line of the heater core, a HVAC hose to connect the defroster vent to the defroster heater box, and I need a new radiator top hose that is not corrugated so that I can install a fitting inline that has a temperature switch to turn on the radiator fan automatically. I currently only have a manual switch on the dash that I physically have to turn on and off.
Thanks for reading!
Heater core, fan, shroud pre-assembly
Lucky penny
Material used to pack around heater core
Heater core installed
Defrost vent
Defrost and heater boxes installed
Heater box door open
Made in Athens
~~ Konstantine
Follow in the DITY
Page 2 of 2 1 2
Moderated by  J Lucas
