Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 87 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
I
I Offline
Hi folks. New member here.
I've got a 1962 Grumman-Olson Kurbside step van, built from the factory on a Chevy P30 chassis and drivetrain with a 235 motor, and 4 speed manual transmission. I've been told it's a bit of a rare bird in that it has a full sized, wooden roll up door in the back (incidentally installed by a local garage door company according to the plaque mounted on it) as opposed to doors.
I bought it as a runner a little over 4 years ago, but I've had to do a ton of work to it since then, as the previous owner literally smoked way too much weed and did all sorts of half-baked (pun intended) work to it.
Here's a list of almost everything I've done over the last four years. It'll be a pretty long list, so bear with me.
I replaced the too small radiator that was previously put in it, finding out that the hoses were basically folded in half (thanks, previous owner! LOL). Of course, I replaced the hoses while I was there and installed a new electric, pull type fan. It works well as is, but I want to find and install a short shaft water pump and pulley so that I have enough room to install a shroud with the fan. That should make it much better. I don't have space for a push style fan.
At the same time, I also removed the heater core to have it repaired by a local old-timer that still does that type of work. I still haven't reinstalled it, but hope to do so within the next month, or so.
I have replaced all of the door handles and locks with OEM replacements from Mill Supply, all keyed alike because the originals had no keys.
There was no glass in the driver, and passenger doors, so I used some really thick, yellow plexi as windows, as well as replacing all the felt channel, and other window related accessories. For now, they are static, but I'll eventually install regulators of some sort, and make my own door cards. I'm going to use what's left of the yellow plexi to make sun visors.
I replaced the original seat which was falling apart and had no seat belt with a Vevor forklift seat which has a tilting back, folding arm rests and, more importantly, a lap belt. I used the original tilting seat post but had to build a new base for the seat to mount to.
I replaced the inner and outer front wheel bearings (it took weeks of searching for the outer bearings. I finally found the only ones available at the time in a shop somewhere in Europe. I needed two, so I bought four. We all know how that goes), and replaced the drum brake shoes front and rear. The wheel cylinders were in good shape and the brake lines were new. I also installed a new OEM master cylinder BUT it's only a single circuit. This winter I'd like to buy, adapt and install a dual circuit setup, for peace of mind and safety.
I had the original emergency brake band clamp relined with new friction material and reinstalled it. It basically clamps around a spinning drum on the propeller shaft. I'm surprised at how well it works!
The glove box piano hinge was rusted solid, so I popped all the rivers, soaked it in EvapoRust, had a key made for the original lock, and re-riveted it in place.
The only gauge it had when I bought it was the temp gauge. I bought the triangular gauge cluster made for an old Apache and installed it. I believe that's what was originally intended to be there. For now, I've got the fuel gauge and Speedo hooked up on the Apache cluster.
When I first bought it, it only had headlights hi/lo, and tail lights. When I decided to look into installing turn signals and wiring up the brake lights, I took a look at the wiring harness and saw what a nightmare it was from the P.O. doing all sorts wacky things to it. It had live wires going to nowhere and nothing, some about 6 feet long and just coiled up and zip tied. Other wires that were split from one, to two, them back to one, back to two and then down to one again. I have no idea a)how this thing ran, b)didn't keep blowing fuses and/or c)didn't catch fire. The P.O. had mentioned it had a parasitic draw, but didn't know why. I found out why HAHAHAHA!
I ended up tearing out all of the wiring and building a new wiring harness from to back. I wired up the headlights, tail lights turn signals, running lights, radiator fan, starter, alternator, ignition system, fuel gauge, external temp gauge and horn. I had searched for two years to find the correct horn button and was ecstatic when I found it.
I still need to wire up all of the gauge cluster lights, interior lights, and the temp gauge on the cluster to replace the external temp gauge. Once I do that I'll replace the external temp gauge with a tach. I'm also going to convert the Ammeter on the cluster with a volt meter, and hook up the oil pressure gauge. At that time, too, I'll reinstall the heater core and wire up the blower to a 3 position switch I have with built in resistors as opposed to just on/off as it was originally hooked up. I still need to paint the blower box. I plan on using gold metal flake on that.
It had been running really rough since I got it so, after looking into it, found out that one reason was vapor lock. The P.O. bypassed the original gas tank and installed a small, auxiliary tank on the front bumper. It would get incredibly hot in the sun, of course. I dropped the original tank and saw that one of the baffles had come undone and fallen into the bottom of the tank. I was able to set it back to upright and spot weld it into place. I couldn't find a pickup tube and sending unit for this tank, so I ended up using a pickup tube I had that was the right length and shape, and then spot welded the sending unit with float from another setup onto that pickup tube. I had to rebend and shorten the arm for the float but now have it to where it works and reads true. I painted the tank metal flake silver, installed a new sending unit gasket, filler neck hose, locking gas cap and repaired and reused the original tank straps with new insulators installed. That took care of the vapor lock. It's a good feeling to be able to see the gas gauge doing it's job.
Another running issue I had was due to the P.O. having installed a Pertronix electronic ignition, but using the original 1.5Ω coil with ballast resistor, rather than a 3Ω coil with no resistor. The secondary windings were failing giving me intermittent problems. I got a Pertronix 3Ω coil and installed it, which took care of that issue.
The final issue I had was realizing that the exhaust manifold gaskets were all blown, as was the donut seal on the header pipe. When I sprayed soapy water on them it looked like a Rave because of all the bubbles.
When I removed the intake and exhaust manifolds (they're bolted together), I saw that my exhaust manifold was cracked, and one of the exhaust ports was canted because of the crack. The entire thing was nowhere near flat, or straight. I planned on trying to repair the crack, but decided to see if I could find a replacement first. It took a few weeks of searching till I found one, because I have an updraft carb. Seems like lots of stuff on this P30 platform is hard to find. The replacement I found was in much better shape than mine. No cracks, flat, and true. I cleaned, painted and installed it using a Remflex gasket, painted the header pipe and installed a new donut for that, then rebuilt the exhaust system using a new muffler from Rockauto, and various tailpipes, turns, and tip. I can happily report that now it runs really well, and dependably, and it sounds really good out of the exhaust. What a good feeling!
Just the other day, I installed a NOS, rebuilt, dual stage fuel pump. I didn't know that was a thing (I'm new to rebuilding old four wheeled vehicles) until I stumbled upon it. After installing it, I ran new vacuum hoses from its vacuum pump (that's the second stage of the dual stage) to the Trico windshield washer co-ordinator valve that was in the engine bay. The internals of the valve don't work anymore, so I used two new, external, one way valves for the vacuum from the pump, and from the manifold, and then up to the wipers. Now, my wipers work really well at idle, and also at speed. No more stopping wipers when the RPMs increase. I absolutely love that. I do have to rebuild the passenger side wiper motor, though, as it doesn't work as well as it should. Also, I bought and installed NOS wiper arms and rubber wipers. The top hat seals that go over the shaft for the wipers were crumbling. They're no longer available, so I had a friend 3D print me a set. Those fit perfectly and are working well.
I've replace the original headlights with LED headlights that look vintage. The headlight rings are currently off a Bel-Air. I have Chevy style ones to replace them with. I also replaced the headlight aim adjusters, as mine were broken from age.
I replaced the original running lights with NOS ones that had functioning bulb sockets. I've since learned you can buy replacement sockets.
I had the carb rebuilt at a local shop in Albuquerque known for their carb work. I had them do it since they had all of the parts on hand and could get it done in a day. I drove there dropped it off, and drove it home the same day.
When I got the Grumman, the carb had a motorcycle style come filter on it. Someone in a Grumman group I'm in was nice enough to send me an original oil bath air filter housing. I cleaned it up, brazed some rust holes, painted it it, made a mounting bracket for it and installed it. I replaced what looked like horse hair air filtering material with stainless scrubby pads I got and hooked it up to the carb. It now drives with more torque and power than before.
I redid the wooden floor in the back and installed e-channel and two motorcycle wheel chocks. There was a lot involved with that. Originally, there were wooden strips, about one inch wide and one inch tall, running from front to back, with a one inch gap in between them. About a foot of the center section of those were missing. I needed something to screw the wood floor to, but didn't want to screw into the aluminum of the bed so I cut 2x4s and ran a few width wise from front to back. I then screwed those into the existing screw holes that were already in the floor from the missing wood strips, and screwed 4x8 particle board to the 2x4s and remaining wood runners.
I'm getting ready to remove the front bumper that's on there (it's off of a Stingray) and that auxiliary gas tank I mentioned earlier, to install a stock, Chevy bumper. I need to make mounting brackets for that.
I think I've listed just about all of the major work I've done up till now. I have a ton more work I plan on doing. I'll post all that as I get it done.
Thanks for all that stuck around and read all of that. I'm looking forward to asking all sorts of questions, and posting my progress. I'm definitely having a lot of fun with this project.
Take it easy!
- Konstantine
Konstantine
U
U Offline
Welcome Konstantine! Wow- that's a lot of work, but looking good. I've heard of updraft carbs, but have never seen one. I'm just starting to work on my vacuum wipers. That secondary pump seems like a good choice. Can't wait for your next update.
~ John in Utah
Here We Go
Follow in his DITY Bay
Nice, Konstantine !
Admirable work there.
The ski goggle yellow is striking!
That rear door is very appropriate and I love the patina.
Hope you just clean it up and varnish it.
Glad you sent pictures, great to see!
Charley
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
I
I Offline
Hey there, and thanks for the warm welcome. It's much appreciated!
Yeah, I've done a ton, and have a tone more to do. I'm glad to have found a good forum to share my escapades and progress on.
I'll attach a pic of the updraft, as well as the two stage pump, the splitter I have, and how I mounted it with the one way valves.
Thankfully, parts for the carb (Carter BB1) are available.
The dual stage pump is mounted with fuel up top, and vacuum below. The vacuum pump has an IN and an OUT port.
The splitter has 4 ports. One is labelled MAN (Manifold). I have a vacuum hose going from the manifold to the splitter, with a one way valve spliced in near the splitter with the arrow/flow of the valve facing the manifold.
The second large port is labelled V. P. (Vacuum pump). I have a hose coming out of the VP port of the splitter, installed a one way valve with the arrow/flow facing the vacuum pump, and the other end of the hose going to the OUT port of the vacuum pump.
Then a hose going from the IN of the vacuum pump going up to the outlet on the splitter that goes to the wiper "motors". I used a Tee there. I attached the other end of the hose coming from the IN of the pump to one end of the Tee, the second end of the Tee is attached to the port coming off of the splitter that goes to the wiper motors, and the third end of the Tee has a hose going up to the wiper motors. In the cab I used a Wye fitting to branch off to the tow motors.
I hope that all made sense and possibly helps!
There was next to ZERO information online about the splitter. It took me a while to figure out the orientation of everything, or that the splitter was supposed to work as the one way valves on its own! Now, my wipers work at idle and when I'm on the gas!
I do have to remove and rebuild the passenger side wiper motor, as it's not functioning properly. That should be interesting...
I
I Offline
Originally Posted by Steelonsteel
Nice, Konstantine !
Charley
Thank you, sir! I appreciate the kind words. I take a lot of pride in making things not only functional, but also appealing.
The plan is to keep the patina, for sure! Partially because I like it, and partially because I'm a little too lazy to polish it and then keep it shiny LOL!
Konstantine
I
I Offline
I hope no one minds, but for anyone interested I'll mention that I have an Instagram account called Insta_Grumman with some pics of the work I've done and am doing.
I also have a YouTube channel called KZ_Kon with a dedicated playlist for my Grumman work, as well as other things I work on.
Cheers!
Konstantine
Former Workshop Owner
J Online: Content
Welcome, cool truck. thumbs_up
Thanks for posting.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I
I Offline
Thanks for posting.
Thank you!
Konstantine
I
I Offline
On my last couple of days off, I was able to finally remove the small gas tank, and the Corvette Stingray front bumper the previous owner had installed on the front of the Grumman.
A bit of sawzall work, and some grinding got both to come off in good shape. I've put both up for sale. Imagine how happily surprised I was when I found out how much that front bumper may fetch. It'll help me offset the price of the new tires I need.
After they were removed, I painted the chassis where the actual bumper will mount with some rust encapsulator I got from Eastwood.
I have a used front bumper off of an unknown Chevy truck. I had to weld a tear in the bottom. I'll have to make my own mounting brackets for it, then paint. I may end up having it powder coated. We'll see.
Fuel cell and Stingray bumper
Sawzall fun
Removed
Rust encapsulator
Painted and ready for the new bumper
Konstantine
I'm digging your hat, Konstantine!
1950 Chevrolet 3100 (Ol' Roy)
I
I Offline
Which hat are you referring to, Otto?
Konstantine
Go back to the pic of the Corvette bumper.
I
I Offline
Oh! Hahaha! I didn't realize it was sitting there 🤣
Konstantine
It's pretty substantial evidence against you (being normal, that is)!
I
I Offline
You would be correct in that assumption 😜
Nothing like wearing your childhood fears on your head while you're working. 🤣
Konstantine
I
I Offline
I got some good work on these two days off.
Since I recently finished installing a Remflex gasket to get rid of my exhaust manifold leak, installed a new donut seal on the exhaust downpipe, installed a new muffler and exhaust setup, and finally installed the original oil-bath air filter in place of the motorcycle style come air filter that's been on my carb since I bought the Grumman, it was time to finally tune my carb.
I used an old rpm/dwell meter I've had laying around forever, and a vacuum gauge I just picked up and got to settings thing right.
Ends up the carb always running a bit lean. It took about a quarter of a turn of fattening it up to get it where it needed to be. Also, my idle RPMs were high at 700. Lowered it down to 500 RPM. Went for a drive and man oh man, what a difference! Much smoother, more power, running a little cooler, even. And with the lower RPM at idle it's easier to put it in gear from a dead stop and, as I release the clutch it's not as jumpy.
The other bit of work I got to do was bend, flare and install a new hard line going from the manifold vacuum to the PCV valve. Just getting to that point was a bit of a challenge because the fittings and tubing sizes are not standard, it seems. Took a while to find the correct sizes.
I also took a heat shielding type of wrap and wrapped the rubber vacuum lines I recently installed that go from the dual action fuel pump/vacuum pump to the wipers.
At this point, after four years of working on the Grumman repairing, replacing and upgrading various systems, with the last 8 months being specifically focused on getting it running right and dependably, I can happily say I've reached that point. I can now turn the key, drive it, and it's running really, really well.
The icing on the cake was installing my coffee cup holder, and placing a sticky rubber mat on the doghouse cover that I can clip my phone onto when I'm using GPS.
Like a said, a good couple of days off, for sure.
Vacuum to PVC hard line
Heat shielding on wiper vac lines
Cup holder and phone mat
Konstantine
Well done, Grasshopper.
I
I Offline
Konstantine
Very clean engine bay.
I
I Offline
Thanks. I cleaned up the driver's side of the MRI and painted the manifolds. I still need to degrease the passenger side and install new silicone gasket I got for the inspection cover.
I also got a silicone one for the valve cover which I want to paint to match the manifolds
I built a new wiring harness and ran or rerouted new everything over the last 4 years, so I tried to make it as neat and tidy as possible.
Konstantine
Kon - Do you recall where you purchased the line for the PCV hardline (from PCV valve to intake vacuum T)? It looks like it's aluminum. Also wondering if you replaced the compression nuts, and if so, were did you find the replacements? headscratch
~ Dan
1951 Chevy 3 window 3100
I
I Offline
Hi Dan,
I've got some good news, and some bad news for you.
It took me a while to find the appropriate sized tubing (yes, what I bought is aluminum), which turned out to be 7/16" O.D. Seems that's a rare size these days.
I ended up having to buy a whole 50ft roll from ebay for almost $90 with shipping. Here is the link:
https://www.ebay.com/itm/186915712799
I bought that much because another roll I found was that price for 20 feet, so I figured more was better than less, and I needed it, so I bit the bullet. And another place sold it by the foot but, for some reason, I didn't buy it there. Maybe expensive shipping? Or it wasn't in stock at the time? I just don't remember.
Here are the other places I found some:
This place sells it by the foot:
https://grapevinesally.com/new-easy-bend-7-16-aluminum-tubing-9-95-per-ft/
This place is $80 for 50ft. not including shipping:
https://shop.partsdepotinc.com/prod...fVwfOzIeC_i-IJZ-kL_U4zPqnU47cXamZpfBDTng
Regarding the fittings, I ended up reusing the ones I already had on the van, even though the threads were chewed, because I only found one place online that had the size I needed, Discount Hydraulic Hose. And, unfortunately, they've been on backorder since August. They have no idea when they'll be available. Hence me using my crappy old ones. Thankfully, they installed well enough to get the job done.
Here is a link to the fittings:
https://www.discounthydraulichose.c...V2x6RRjS7XOQrkUL-1axe1Prq18aAveNEALw_wcB
I hope that helps.
Konstantine
Kon - Thanks so much for your detailed info. I knew the tubing is 7/16" OD, but like you found the amount and cost for a 50' roll way more than I needed/wanted to bite the bullet on. Looks like I'll have to settle for trying to recondition my existing fittings/hardware too.
PS - I'll send you a PM a bit later. wink
~ Dan
I
I Offline
Hi Dan,
I wasn't sure if you also needed 7/16" OD tubing. Since you do, and I have a bunch left over, can I send you some? I do want to hang onto enough that in case I need more in the future, I have it. That being said, I believe I have enough that I can send you some, depending on the length you need.
Let me know in your PM you're sending. smile
Hopefully, your fittings work out! Regarding those, I've left mine on back order, assuming they'll eventually be available again. I had to order 5 fittings to meet their minimum order quota. If they ever do come off back order and I get all 5, I'll let you know and can send you a couple of those, as well. smile
Konstantine
Kon - Thanks for the offer. Let's move the conversation to a PM as further conversation and personal details should be conducted/shared there per our forum guidelines. wink
~ Dan
I
I Offline
Gotcha, Dan.
Ok then, I'll keep an eye out for your PM.
Konstantine
It's in your "in-box". wink
~ Dan
I
I Offline
I got to do a bit more work on the Grumman. I decided to do some fun, and smaller things to mix things up a bit, as I mostly been working in crucial repairs and upgrades to get it running and dependable, for quite a while now.
First, I cleaned the body of the doghouse. I want to maintain the patina on the Grumman, but want to get rid of the dirt and grime. I used some warm water with dish soap in it to get rid of the dirt and grime, then some Nevr-Dull wading to clean things up. I actually have about 8 cans of it that I will use on the entire vehicle at some point.
The doghouse came out looking good but, I'm really sad to say, I had a casualty. It seems the Never-Dull had a chemical reaction with the data plate, causing the black color to slowly disappear. It was pretty black when I started. The photos show it starting to disappear. About 5 minutes later, all of the color was gone. That really upset me. At least, I learned a good lesson. I'm going to see if I can have the information reproduced on a water slide and put that on the plate, then clear over it.
I also adhered some rubber channel around the edges of the doghouse. It's now ready to be re-installed.
Next, I replaced the top hat washers that cover the shafts of the windshield wipers. Mine were in horrible shape, cracked and crumbling. I had a friend make some new ones fore on her 3D printer, out of material especially designed for outdoor use, with UV protection. They came out great! If anyone needs some, she has them listed on eBay.
My next endeavor was to remove the rims to install push throughs I had purchased, mainly to dress things up a bit. I had installed long, chrome lug nuts a while back. I've actually wanted beauty rings but, sadly, I can't find them anywhere in 19.5. There was one company that made them, but they've been out of business for quite some time.
My other option was push throughs. I measured my openings at 4.75 inches. I scoured the Internet for weeks till I found what I thought were the appropriate push throughs. I found one pair as NOS from one seller, and the second pair as good-used condition from a other seller. They were the only ones I found online after all that searching listed as 4.75 diameter.
As I tried to install them, they turned out to be too big. They're around 4.81 inches in diameter. Dang it. Oh well, back to the drawing board.
I have looked into getting 17 inch rims. Unfortunately, I'd either have to get tires that are too short, significantly decreasing my top speed while increasing my RPMs too
much, in my opinion or, getting tires that are tall enough but are a bit too wide causing fitment issues unless I alter my brake setup.
So, I'm going to stick with my 19.5s and hope to find either trim rings, or push throughs that fit, at some point
I did end up ordering new tires yesterday for the 19.5s.
225/70R19.5 as opposed to the 8R19.5 that are currently installed. My 8Rs all have cracked sidewalls. The 225s are a smidge shorter, which I wanted (the RPMs shouldn't increase too drastically) and a smidge wider, enough to make a difference but not enough to have a fitment issue. Also, they are 14-ply, so a little less stiff than the 16-ply I currently have.
My final bit of "work" was to put a chicken sticker on my choke knob. I'll let you figure out the reference 🤣
That's it for now!
Doghouse clean with rubber edge
Doghouse again
Doghouse data plate disappearing
Top hat seals before and after
Top hat seal installed
Push through
Chicken knob
Konstantine
Sounds like you're having fun with it. Except for the data plate issue. frown If you have a good enough picture of it you could make a decal from that with a little tweaking. I've done decals on my ink jet printer, but the best bet is to take the photo file to a print shop with a laser printer.
Still working on the "CLUCK" sticker. headscratch
I
I Offline
Thanks! Yeah, lots of fun for sure, but I am really bummed about the data plate.
My friend does waterslide decals. Same person that 3D printed the top hat seals for me.
She's going to make me labels for my dash and heater box when I'm done with all of that, so I'll ask her if she can make me one for the data plate.
So, regarding the chicken sticker, the cluck part is incidental. The main idea is it's the choke, and it's a chicken. Choke the chicken... 🤣
Silly, I know. It evolved from a joke with me and my best friend.
Konstantine
I
I Offline
Hey, I just now saw your photo! HAHAHAHA!
Awesome hat! Seems like great, and crazy minds think alike.
Konstantine
R Online: Content
I figured that's where you were going with the chicken knob.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I
I Offline
Nothing like being a bit silly wink
Konstantine
I
I Offline
Well, the plan yesterday was to install a new GM style headlight switch to replace the off-the-shelf two position headlight switch I have but, as with many well-laid plans, I realized that was missing some components so I had to pick another direction.
What I ended up doing was finally painting the heater box and blower box for the interior of the Grumman. I had purchased some gold metal flake paint quite some time ago, but ended up having to work on more essential things until now. The nice thing about being able to paint means I'm actually closer to done with the essentials and can focus more on the smaller and more fun bits!
The first pick is of the vertical defroster vent which I painted last year in flat black. That's going to stay that color.
The other photos are of the gold metal flake paint I used with a 2K clear I bought from Kustom Canz. I like the quality of the product. It sprayed well, other than every once in awhile the tops were spitting, but it was manageable.
One can of their black base coat was more than enough for the two pieces given that I had also primered them in the same color. One can of gold flake was emptied getting the results you see in the pics on the two pieces. I'm happy with the results and will say the pictures don't do them justice.
Hopefully, next week I'll be able to install them and keep moving forward!
Vertical defroster vent
Heater and blower box prep
Final paint
Final paint
Final paint
Final paint
Final paint
Mad Scientist
Kustom Canz
Konstantine
Looks like they turned out great Kon! thumbs_up
~ Dan
I
I Offline
Thank you! It's slowly coming together.
Konstantine
Moderated by  J Lucas
