0 members (),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 148 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 148 | What would be the proper Carb(s) for a 261 Pontiac with 848 Head?
Single carb or double, used or new? | | | | | Joined: Sep 2009 Posts: 6,045 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,045 | Joerg - That depends on a few things. Basically it would have been a single barrel Rochester Model B (if manual choke) or BC (if automatic choke - more used on car engines than trucks). The Chevy truck 261's used a larger version of the Rochester B than the 235 and even smaller 216 versions. You can check out Rochester carb identification info in several "Tech Tips" found HERE. There are alternative carbs from the Rochester, like the Carter YF series, which many folks prefer, but again you'll need to be sure you get one that at a minimum is for a 235 or 261 engine. If you want simplified use/maintenance and tuning, stick with one single barrel carb. You can certainly go dual carbs, but that can become a real pain in the you know what to setup and balance. On the used or new question, you will not likely find any "real" Rochester or Carter carbs, only used/rebuilt ones. The "new' stuff being offered looks pretty and close to accurate, but is all made overseas and more often than not is barely usable out of the box. They are known for very poor quality unfortunately.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | Good morning Joerg - the 1961 (possibly later as well) Canadian Pontiac used a Carter type AS carburetor number 3114s.
The type AS was basically designed as a 60,000 mile "throw-away" unit; rebuilding one is a nightmare.
Regards.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Just from an engine displacement perspective, the Carter YF for an AMC/Jeep 258 cubic inch six looks like it would be a good choice. Fuel line routing and throttle linkage would probably need to be tweaked a little. Maybe Jon would be willing to weigh in on the feasibility of that idea? Jerry
| | | | | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | What would be the proper Carb(s) for a 261 Pontiac with 848 Head?
Single carb or double, used or new? A couple of gentlemen have offered suggestions. I don't necessarily agree or disagree, as you have not really given us a reason behind the question. BASED ON YOUR DESIRES FOR THE ENGINE, you have many options: (1) The original Carter type AS 3114s. In my opinion, NOT a really good carb, but it was calibrated for the engine and everything fits. Should you choose this option, I would look for a new old stock unit. There is virtually zero market for any of the type AS. We have several new old stock, just none of this number. If you find a new old stock 3114s, I don't think you will find it to be gold plated (2) Another single carburetor; Jerry's idea of a AMC/Jeep 258 Carter YF is a sound suggestion. (3) You mentioned a double carb arrangement. I would suggest this may be the worst option, as the intake to head interface is not optimal for two carbs. (4) If you want multiple carbs, then three is MUCH better than 2, because of the afore-mentioned intake to head interface. Three Willys Jeep type W-0 ID number 636s would be ideal. (5) A Clifford intake with a two or small four barrel. Should you consider this option, carefully consider the definition of the word "small". Carter produced a couple of WCFB four barrels for Studebaker (2214s and 2219s) that flow just under 300 CFM, AND THAT IS OCEANS for the 261 for street use. Anything larger MIGHT run worse than the original unless the engine is highly modified. If you go with the two barrel, then the AMC Jeep 258 two barrels might be good options. Remember that should you do anything other than original, possible modifications might include: intake, linkage, fuel lines, fuel delivery, air cleaner, and maybe relocating other engine accessories. Should you wish a recommendation, please give us more information about the state of tune of your 261, and your plans for the build. Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2008 Posts: 148 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 148 | Just quickly some info to the 261. It is a (supposedly) rebuild engine that came with my 1953 1/2 ton. The 261 has no oil pan, but single carb intake & standard exhaust. I need to check this engine over completely, bore, crankshaft & connecting rod bearings, leak-down test etc., to see if this engine really is 'rebuild' or if someone stated what is not true. New paint doesn't make a rebuild engine. Jerry's idea of a AMC/Jeep 258 Carter YF sounds to me the best way for my use, I am not going to race this truck. I have gotten a lot of info here and need to digest this all and check clearance under the hood & needed modification. A quick search shows many options and I will only example one here: 258 Carter YF sample | | | | | Joined: Mar 2013 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 225 | my suggestion was a Clifford manifold for a single carb,1,2 barrel or 1, 4 barrel. i would not recommend two of anything!! i've been that rout many times. | | | | | Joined: Mar 2008 Posts: 148 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 148 | Thanks jay d, sorry for my ignorance on intake headers & carb's.
It is not really my field of expertise and I will need more coaching than a website link once we get closer. We got time, probably 2-4 month, maybe 6. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I've also been researching the possibility of doing some machining on a stovebolt intake to adapt the carburetor footprint for a Rochester 2G carburetor for a Chevy 265 V8. That would involve milling away the one barrel carb flange and welding/brazing a 4 bolt flange on to match the 2BBL base, with a minimum of restriction between the carb base and the manifold runners. I believe there's a Bendix 2 barrel carb for a 270 cubic inch MOPAR V8 from the late 1960s that might be a good match, displacement wise. Jerry
