2 members (3B, 1955 1 Series), 132 guests, and 2 robots.
Topics128,195
Posts1,057,369
Members48,469
What would be the proper Carb(s) for a 261 Pontiac with 848 Head?
Single carb or double, used or new?
JoergK.
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along in the DITY Bay
Joerg - That depends on a few things. Basically it would have been a single barrel Rochester Model B (if manual choke) or BC (if automatic choke - more used on car engines than trucks).
The Chevy truck 261's used a larger version of the Rochester B than the 235 and even smaller 216 versions.
You can check out Rochester carb identification info in several "Tech Tips" found HERE.
There are alternative carbs from the Rochester, like the Carter YF series, which many folks prefer, but again you'll need to be sure you get one that at a minimum is for a 235 or 261 engine.
If you want simplified use/maintenance and tuning, stick with one single barrel carb. You can certainly go dual carbs, but that can become a real pain in the you know what to setup and balance.
On the used or new question, you will not likely find any "real" Rochester or Carter carbs, only used/rebuilt ones. The "new' stuff being offered looks pretty and close to accurate, but is all made overseas and more often than not is barely usable out of the box. They are known for very poor quality unfortunately.
~ Dan
1951 Chevy 3 window 3100
Carburetion specialist
Good morning Joerg - the 1961 (possibly later as well) Canadian Pontiac used a Carter type AS carburetor number 3114s.
The type AS was basically designed as a 60,000 mile "throw-away" unit; rebuilding one is a nightmare.
Regards.
Jon
The Carburetor Shop
Just from an engine displacement perspective, the Carter YF for an AMC/Jeep 258 cubic inch six looks like it would be a good choice. Fuel line routing and throttle linkage would probably need to be tweaked a little. Maybe Jon would be willing to weigh in on the feasibility of that idea?
if i were to build a 261 for myself it would have a Clifford or 4 barrel intake with a 2 barrel adapter or a small 4 barrel carb, of course all jetted properly. i see them at swap meets in the 200 - 300 price range.
https://cliffordperformance.net/store/ols/products/42-4500wh-chevy-235-intake-manifold
