| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2023 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 9 | I am in need for 4 16x4.5 or 16x4 6 lug standard wheels for my 1941 1/2 ton truck that the tire tube area is not severely corroded, not worried about light corrosion. From reading the parts catalog these rims came on 39-48 passenger cars and 1/2 ton trucks.
I have found a few on ebay but I am not looking to spend a small fortune on wheels and a lot of them are horrible.
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | The 37-38 wheels would originally be 4.0 inches wide between the beads, but the 39-55.1 1/2 ton's used 4.5 wheels that look identical to the 4.0 wide wheels. That's according to the parts listing, although the vehicle info kits say the 4 inch wide wheels were used up thru 1949. They are both pretty common. I found a 4.5 inch wheel at the storage yard where I keep my pickup camper. Take a tape measure with you when checking.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2023 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 9 | Thank you for the information I did make a mistake in the listing and you are correct the factory wheels are indeed a 16x4 with the original part number being 599885, The main reason I put down just 16x4.5 is because 99% of the wheels I found out there are labeled that. It also depends where you measure in the bead area at the top of the rim it comes out like a 4.5 and at the bottom of the bead area it comes out closer to 4. But I want to thank you for your information and help. | | | | | Joined: Jul 2022 Posts: 97 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 97 | I have extra wheels that I believe are what you are looking for. I blasted and powder coated 7 and used 5 for my ‘40 half ton. I will check if I can find numbers on any of them. I never measured them to see what the width was because the spare that was underneath still had a 6.5-16 bias-ply on it and all the wheels were the same as it. I put 6.5-16 radials on mine with no tubes and they don’t leak. Granted, I took the better of the lot but I think I have 5 or six available. 2 of them painted. | | | | | Joined: Feb 2023 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 9 | If you could do me a favor and see how ide they are, I already have the tube type tires that belong to the truck, I am building the truck as a original stock truck. | | | | | Joined: Jul 2022 Posts: 97 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 97 | They measure 4” at the bead seat area. | | |
