4 members (rfs56trk, TUTS 59, Otto Skorzeny, Tinker5), 62 guests, and 3 robots.
Topics128,268
Posts1,058,187
Members48,482
I am in need for 4 16x4.5 or 16x4 6 lug standard wheels for my 1941 1/2 ton truck that the tire tube area is not severely corroded, not worried about light corrosion. From reading the parts catalog these rims came on 39-48 passenger cars and 1/2 ton trucks.
I have found a few on ebay but I am not looking to spend a small fortune on wheels and a lot of them are horrible.
The 37-38 wheels would originally be 4.0 inches wide between the beads, but the 39-55.1 1/2 ton's used 4.5 wheels that look identical to the 4.0 wide wheels. That's according to the parts listing, although the vehicle info kits say the 4 inch wide wheels were used up thru 1949. They are both pretty common. I found a 4.5 inch wheel at the storage yard where I keep my pickup camper. Take a tape measure with you when checking.
Thank you for the information I did make a mistake in the listing and you are correct the factory wheels are indeed a 16x4 with the original part number being 599885, The main reason I put down just 16x4.5 is because 99% of the wheels I found out there are labeled that. It also depends where you measure in the bead area at the top of the rim it comes out like a 4.5 and at the bottom of the bead area it comes out closer to 4. But I want to thank you for your information and help.
I have extra wheels that I believe are what you are looking for. I blasted and powder coated 7 and used 5 for my ‘40 half ton. I will check if I can find numbers on any of them. I never measured them to see what the width was because the spare that was underneath still had a 6.5-16 bias-ply on it and all the wheels were the same as it. I put 6.5-16 radials on mine with no tubes and they don’t leak. Granted, I took the better of the lot but I think I have 5 or six available. 2 of them painted.
Brendan
1940 Chevrolet 1/2-Ton Pickup
Restoring Dad's old truck
If you could do me a favor and see how ide they are, I already have the tube type tires that belong to the truck, I am building the truck as a original stock truck.
They measure 4” at the bead seat area.
Brendan
OK thank you for checking, i'm gonna go look at some wheels today that are local that didn't even know someone had. Depending on the condition and how many I can get I'll get back to you.
Thank you for everyone's help, I was actually able to obtain a complete set today from a person that was literally a half hour from my house. I never this person had antique stuff hidden in a barn on his property.
Dragracefan -Congrats on finding what you needed locally, and reporting back on your success! thumbs_up I'll leave your post up for today so anyone looking can see the results, then remove it afterwards. wink
~ Dan
1951 Chevy 3 window 3100
