1 members (Charles in CA), 103 guests, and 2 robots.
Topics128,140
Posts1,056,771
Members48,454
#1613018 10/10/2026 9:41 PM
What's the big hole in the bell housing for on the driver's side? Basically, it's a mirror image of the timing hole on the passenger side but slightly larger.
1950 Chevrolet 3100 (Ol' Roy)
It's there to make Otto ask questions. grin
H Online: Content
Ventilation for clutch cooling, most likely- - - - -although it might be possible to add a pointer to time the engine on a cylinder different than #1.
It's used for the timing pointer south of the equator where the engines turn the opposite direction. grin
Crusty Old Sarge
Crusty Old Sarge
Do the GMC engines use the same Bellhousing? Could it be for timing marks on one of those?
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Anyone know that there is a plug that is supposed to go in there? It is made of what appears to be rubber which would explain why they aren't found very often. Rubber does not last anywhere near 70 years.
I have one. It is black and has a crown on the exposed surface. Its density is similar to a hockey puck.
GMC timing window is on the same (starter) side of the engine that Chevies are.
7
7 Offline
I would believe that a reverse rotation stovebolt engine would exist. Marine, industrial, military, etc. would probably be customers.
I once used that hole for timing when I had a 235. Honest. It ran very, very poorly but I finally came to my senses.
Did you paint a mark on the flywheel or something, Wally? And why not use the other hole that already has a pointer on it?
I thought there might have been a rubber plug that was supposed to be there. That's what prompted me to ask the question in the first place. I have a bunch of rubber plugs left over from the Little Red project. I used one on the shift column. Maybe one will fit the flywheel hole.
There was a bolt-hole on the flywheel.
Stupid me.
Oh, are you saying you tried to set your timing using that whole by mistake?
Yes
I just took a quick look at the spare bell housing I have. The hole in question is machined, and MAY be lined up with the pocket for the clutch throwout arm pivot ball (I didn't look that closely.) That would be how that pocket was machined in the bell housing. If someone REALLY wants to know, I could go inspect more closely.
What prompted me to go look was the talk about a rubber plug for the hole. Why would GM machine a hole only to plug it up again?
Again, that's why I ask all kinds of questions about innocuous things on these trucks , like the upside down coil. There are reasons for everything and I just like to know what they are.
Originally Posted by Wally / Montana
Yes
That's funny. I did the same thing when I first got the truck running and wondered why there wasn't a BB. Then I saw the other hole.
U
U Offline
Maybe some type of inspection hole? Adjustment hole?
~ John in Utah
Here We Go
Follow in his DITY Bay
John, your bell housing is a bit different than the AD ones, with those two "windows" near the top where it bolts to the block where the AD housing I have is solid.I see now that my assumption that the hole in question being lined up with the clutch arm ball (I was remembering it as a socket, but that's on the arm itself) is incorrect.
So the mysterious hole is still mysterious. Nothing there to adjust, but maybe a spot for engaging the flywheel teeth to bar the engine over?
