0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,902 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,902 | What's the big hole in the bell housing for on the driver's side? Basically, it's a mirror image of the timing hole on the passenger side but slightly larger.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | It's there to make Otto ask questions.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Ventilation for clutch cooling, most likely- - - - -although it might be possible to add a pointer to time the engine on a cylinder different than #1. Jerry
| | | | | Joined: Jan 2022 Posts: 2,478 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,478 | It's used for the timing pointer south of the equator where the engines turn the opposite direction.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2007 Posts: 3,431 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,431 | Do the GMC engines use the same Bellhousing? Could it be for timing marks on one of those?
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Anyone know that there is a plug that is supposed to go in there? It is made of what appears to be rubber which would explain why they aren't found very often. Rubber does not last anywhere near 70 years. I have one. It is black and has a crown on the exposed surface. Its density is similar to a hockey puck.
| | | | | Joined: Jan 2022 Posts: 2,478 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,478 | Do the GMC engines use the same Bellhousing? Could it be for timing marks on one of those? GMC timing window is on the same (starter) side of the engine that Chevies are.
