2 members (SammyC60, klhansen), 135 guests, and 3 robots.
Topics128,101
Posts1,056,518
Members48,448
#1612112 09/27/2026 7:22 PM
If I shake or jostle my coil (in my hand , not on installed), I can hear the oil in it sloshing around. I've never noticed this before on any other coil. There aren't any leaks and everything appears to be working properly so it probably doesn't matter.
If it does, let me know.
1950 Chevrolet 3100 (Ol' Roy)
Virtually all can-type coils are oil filled. If you can feel the oil sloshing around, the coil has lost some of the volume of oil it was manufactured with. I'd be prone to have a replacement unit handy to keep from getting stranded when (not if) it fails.
Gotcha.
I've never heard that sloshing before so I thought it was unusual.
There hasn't ever been any evidence of oil leakage from the coil, however but I will order a new one
I had a coil explode and it blew oil all over the place.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Holy Schneikes!
A little Bondo should get that coil working again.
No! No! Use Duct Tape. grin
Please keep this thread on topic so I don’t have to move it to the spoon.
And it’s DUCK TAPE
Another quality post.
Real Trucks Rattle
Micky, what was the cause of the failure?
AD Addict & Tinkerer
The failure was caused by an overheated ignition coil. When the coil overheated, it transferred excessive heat to the surrounding oil, causing the oil to expand and subsequently leading to the coil failure.
This overheating could have been triggered by the ignition switch left in the "on" position while the engine was not running. If the points just happen to be in the closed position, this would result in a continuous dead short. This sustained electrical draw causes the coil to rapidly overheat. Alternately, the coil itself may have had an internal failure or breakdown in insulation, causing it to draw excessive current and overheat during normal operation.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 was correct.
Otto I had been working on something and forgot and left the ignition key in the ON position. Didn't discover it until the next morning.
And it’s DUCK TAPE
I figured everybody knowd that...
It was originally (and still is) duct tape. Heavy duty aluminum foil backed tape used for sealing joints in HVAC ducting.
The household silver tape we use today with plastic backing, that isn't the metallic backed tape used for actual duct work, was called Duck Tape during WWII.
Duck tape, Due to the fact that it was invented WWII to seal ammo boxes, and made of cotton-duck fabric.
Now that’s established, let’s get this thread back on track.
I wonder if exploding coils had anything to do with mounting the coil wire facing down.
Phil
Project Journals
Phak1 #1612858 10/08/2026 8:29 PM
Not likely, if the coil was sealed, it wouldn't matter. The expanding oil as it was being heated would find a way to rupture the case in either position. No idea whether there would be any actual explosion (combustion of the oil) involved.
I like to install the coil with the wires on top to keep the electrons from leaking out.
But if you do it that way the electrons have to go uphill to get over the top of the loop in the high voltage coil to distributor wire.
It's a no win situation!
