2 members (1955 1 Series, Bill Hanlon), 68 guests, and 2 robots.
Topics128,263
Posts1,058,136
Members48,482
#1612112 09/27/2026 7:22 PM
If I shake or jostle my coil (in my hand , not on installed), I can hear the oil in it sloshing around. I've never noticed this before on any other coil. There aren't any leaks and everything appears to be working properly so it probably doesn't matter.
If it does, let me know.
1950 Chevrolet 3100 (Ol' Roy)
Virtually all can-type coils are oil filled. If you can feel the oil sloshing around, the coil has lost some of the volume of oil it was manufactured with. I'd be prone to have a replacement unit handy to keep from getting stranded when (not if) it fails.
Gotcha.
I've never heard that sloshing before so I thought it was unusual.
There hasn't ever been any evidence of oil leakage from the coil, however but I will order a new one
I had a coil explode and it blew oil all over the place.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Holy Schneikes!
B Online: Content
A little Bondo should get that coil working again.
No! No! Use Duct Tape. grin
Please keep this thread on topic so I don’t have to move it to the spoon.
And it’s DUCK TAPE
Another quality post.
Real Trucks Rattle
Micky, what was the cause of the failure?
AD Addict & Tinkerer
The failure was caused by an overheated ignition coil. When the coil overheated, it transferred excessive heat to the surrounding oil, causing the oil to expand and subsequently leading to the coil failure.
This overheating could have been triggered by the ignition switch left in the "on" position while the engine was not running. If the points just happen to be in the closed position, this would result in a continuous dead short. This sustained electrical draw causes the coil to rapidly overheat. Alternately, the coil itself may have had an internal failure or breakdown in insulation, causing it to draw excessive current and overheat during normal operation.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 was correct.
Otto I had been working on something and forgot and left the ignition key in the ON position. Didn't discover it until the next morning.
And it’s DUCK TAPE
I figured everybody knowd that...
B Online: Content
It was originally (and still is) duct tape. Heavy duty aluminum foil backed tape used for sealing joints in HVAC ducting.
The household silver tape we use today with plastic backing, that isn't the metallic backed tape used for actual duct work, was called Duck Tape during WWII.
Duck tape, Due to the fact that it was invented WWII to seal ammo boxes, and made of cotton-duck fabric.
Now that’s established, let’s get this thread back on track.
I wonder if exploding coils had anything to do with mounting the coil wire facing down.
Phil
Project Journals
Phak1 #1612858 10/08/2026 8:29 PM
Not likely, if the coil was sealed, it wouldn't matter. The expanding oil as it was being heated would find a way to rupture the case in either position. No idea whether there would be any actual explosion (combustion of the oil) involved.
I like to install the coil with the wires on top to keep the electrons from leaking out.
B Online: Content
But if you do it that way the electrons have to go uphill to get over the top of the loop in the high voltage coil to distributor wire.
It's a no win situation!
I did a Google search on exploding coils. In one example the gentlemen had rented a small wood frame house with a garage with white painted walls. He had a T bucket roadster, with 12 volt ignition. He turned on the inside garage lite one morning and saw thousands of small black spots adorning the walls and ceiling; they were everywhere and were stuck like dots of black glue. Further inspection revealed the top of the coil had exploded.
I found several other posts that had the same experience with coils that exploded, leaving those same glue like black dots everywhere.
So my first thought on the coil facing down, was that it would minimize the cleanup if the coil did explode. My second thought, “Not Likely”. Must be another reason!
Phil
Project Journals
My coil was upright with the hood closed so cleanup was limited to the engine compartment. 😕
24601
24601
I, too, would like to know why coils are mounted upside down. I always figured there had to be a reason other than "for a neater appearance."
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
It makes no sense to me. You can't easily access the wire connections or the high tension lead. As for "neater" appearance. Is it really neater?
Our AI overlords say that GM mounted it upside down to keep water away from the high tension terminal. Perhaps 75+ years ago without the benefit of silicone rubber, this may have been valid.
However, I've seen many different antique vehicles with the coil mounted straight up, sideways, etc. My 1939 Packard mounts straight up. 1935 Auburn mounts straight up , as well. If there was a real danger of water getting in, I'd think the luxury makes would have mounted it downward or installed a cover or something. They didn't so I think that reason is bogus.
AI also says that mounting it upside down means the wire could be made shorter, costing less money. Seeing some of GM's other cost cutting measures, that sounds like the primary reason to me.
A story that might have some bearing on the coil mounting position. Driving my Model A pickup thru Kansas back in the late 60's we encountered a downpour and it shorted out the coil (the hood hinge in the center isn't waterproof.) I got out, was soaked to my underwear immediately, threw a tarp over the hood and dried things up. Restarted and drove to an underpass to wait out the storm. Older Chevy trucks share the same center hinged hood. So maybe that was a carryover. The AD hoods also have a joint in the center of the hood that isn't totally waterproof as well.
A quick search across various automotive forums reveals that this is a surprisingly common debate—and one that is difficult to pin down with a definitive answer. It turns out that some coils genuinely do have a specific directional requirement based on their internal construction. For example, older Volkswagen coils must be mounted vertically (towers facing down) because their internal ballast resistor needs to be constantly immersed in oil; otherwise, it risks overheating and failing.
However, that doesn't seem to be a universal rule, particularly when we look at our own AD-series trucks. We have plenty of examples of coils mounted in both directions, seemingly functioning just fine either way.
It becomes pretty clear that this debate has been rolling on for decades, long before the internet even existed. But now, coupled with the current mountain of conflicting advice, half-truths, and general "BS" encountered online today, it feels like a question we may never get a straight, universally accepted answer to.
Phil
Project Journals
Somewhere on a GM / Chevrolet design spec sheet it was written down. There's always a reason things are done a certain way.
The same 6v coil part number is utilized by all GM makes and some of the independents. In all these cases, the orientation permits the shortest possible high tension lead.
1951 Pontiac coil is mounted horizontally angled slightly downward.
1951 Buick is mounted horizontally on side of engine with wires pointing toward the dizzy behind it.
1951 Cadillac coil lays horizontally on top of the intake manifold, behind the carburetor facing driver side.
1951 Oldsmobile coil lays horizontally on top of intake manifold behind the carburetor facing passenger side.
1951 Kaiser 6cyl uses the same 6v coil as GM. Coil is mounted on driver side of engine vertically with wires on top.
1951 Studebaker V8 mounts the same coil on the firewall with the wires on top angled upward.
