8 members (WICruiser, Wheelie, Gdads51, Bill Hanlon, SWEET, TUTS 59, Phak1, 1955 1 Series), 90 guests, and 3 robots.
Topics128,187
Posts1,057,325
Members48,469
Dont laugh... All my cars since I was 17 where Hondas... Teflon and nylon lined suspension parts need NO grease or lubrication.
I took a few minutes today to 'grease up' the Ol'green, for the first time in three years.
The result? Re-discovering just how well this truck rides...
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Whizz,
I will refrain from laughing at you. grin
Are you sure you found all the zerk fittings?
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
Greg, I did my best to find them all...
I stopped looking when a drop of superheated motor oil dripped down my neck while under the truck.
I was anointed with 20w50.
I guess that makes me a true 'greaser'?
Whizzer: you need to get your hands dirty more often. Come on out to the farm Grandpa Corn (my Dad) will show all about those Zerks. You didn't go to the field with out hitting those grease zerks in the morning. grin popcorn The Truth is Out There (my 59 has all stainless they sure are purty)
Congratulations Whizz!
You are now a "greaser" LOL!
Did you find the grease cup for your generator yet?
What no zerks on your whizzers?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I've finally gotten my 16 year old convinced that the brake bleeder valves are not zerks! grin
Fred
52 3600
69 C-10
Well, at least the brake bleeders are not rusting grin
Speaking of zerks, I removed most of mine and cleaned the zerks, and then sprayed carb cleaner into the cavity where the grease is "supposed" to go, only to find that I had lots of gunk. I kept cleaning and then re-installed the zerks. Some worked fine and accepted grease, but others would not (they all worked fine after cleaning and off of the car). What do I need to do to fix the problem. Without grease somethings gonna wear out fast. Most of the zerks that were problems were on the spring shackles and the front end steering parts.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
50-four-bruce!
When you have those zerk fittings out you can insert a sharp object (wire etc?) and poke around in the hole to loosen up that crusted grease. I got all my stubborn fittings to work that way. Also, use a pry bar on those shackles between the frame and spring to take the weight off and then try to give it some grease. That works quite often!
Geo.
