0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1611225 09/12/2026 7:07 PM
Insomniac
Insomniac
I have a bench grinder mounted on a stand. I have not used it for several years since it's just easier to grab an angle grinder. Recently, I got a band file* which I find is great for sharpening things. Wanting to reduce clutter, I think the bench grinder should be disposed of.
*band file: Maybe you know it by another name? This is it: https://www.dewalt.ca/en-ca/product/dcm200e1/dewalt-20v-max-xr-18-bandfile-kit
Gord 🇨🇦
1954 1/2 ton 235 4 speed
H Online: Content
Use it a while before you decide. I have the same kind of accessory that fits one of my angle grinders- - - - -even with a speed control attached, it goes through belts in a big hurry, and there are still jobs my three bench grinders do best. They're set up for different jobs- - - - -wire wheel buffing, metal polishing with muslin and hard felt wheels, grinding high speed steel and carbide machine tool bits, etc.
I have pretty much every grinder and sander there is including at least 4 bench grinders with different wheels on them. My bench grinders get the most use.
I'd keep the bench grinder too. I have one that needs a new wheel, as the original one is worn down from use. I have three angle grinders as well, and a small sanding belt style knife sharpener.
Former Workshop Owner
I just added two more to my shop my son was getting rid of. They’ll all have their special purpose.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
S Online: Content
I find it hard to believe that the bench grinder isn’t the most used tool/machine in any shop.
I have several.
I don’t have one on a pedestal, but I plan to make one.
Maybe the pedestal one takes up too much room, floor space…..
I have a “ belt file”. It eats belts.
But, each to their own.
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
H Online: Content
I've made grinder pedestals from discarded flywheels. Remove the ring gear to prevent floor damage as it's rolled around the shop, and add a length of pipe and a piece of steel plate to attach the grinder. Then position the grinder near the work that needs to be done.
Moderated by  MNSmith
