Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
#1611225 09/12/2026 7:07 PM
Insomniac
Insomniac
I have a bench grinder mounted on a stand. I have not used it for several years since it's just easier to grab an angle grinder. Recently, I got a band file* which I find is great for sharpening things. Wanting to reduce clutter, I think the bench grinder should be disposed of.
*band file: Maybe you know it by another name? This is it: https://www.dewalt.ca/en-ca/product/dcm200e1/dewalt-20v-max-xr-18-bandfile-kit
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Use it a while before you decide. I have the same kind of accessory that fits one of my angle grinders- - - - -even with a speed control attached, it goes through belts in a big hurry, and there are still jobs my three bench grinders do best. They're set up for different jobs- - - - -wire wheel buffing, metal polishing with muslin and hard felt wheels, grinding high speed steel and carbide machine tool bits, etc.
I have pretty much every grinder and sander there is including at least 4 bench grinders with different wheels on them. My bench grinders get the most use.
I'd keep the bench grinder too. I have one that needs a new wheel, as the original one is worn down from use. I have three angle grinders as well, and a small sanding belt style knife sharpener.
Former Workshop Owner
J Online: Content
I just added two more to my shop my son was getting rid of. They’ll all have their special purpose.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I find it hard to believe that the bench grinder isn’t the most used tool/machine in any shop.
I have several.
I don’t have one on a pedestal, but I plan to make one.
Maybe the pedestal one takes up too much room, floor space…..
I have a “ belt file”. It eats belts.
But, each to their own.
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
I've made grinder pedestals from discarded flywheels. Remove the ring gear to prevent floor damage as it's rolled around the shop, and add a length of pipe and a piece of steel plate to attach the grinder. Then position the grinder near the work that needs to be done.
Bench grinders are best for me when set up for a specific task. Baldor with two diamond wheels for precision on wood lathe tools, coarse wheels on old Milwaukee with coarse brush and one old b line with fine wheel and fine brush. Probably still need buffing wheels on another.
1959 Apache 31
I think I paid about $400 for my long shaft 2 speed buffing machine. There are options out there for $100 for similar machines. I have never used one. If they have enough power and you don't use it much they might be worth looking into.
I have a pneumatic air file from Harbor Freight. I recommend buying 3M belts for it. They last much longer.
I use it mostly for knocking down the high spots on welds on body panels.
Moderated by  MNSmith
