0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | I have a bench grinder mounted on a stand. I have not used it for several years since it's just easier to grab an angle grinder. Recently, I got a band file* which I find is great for sharpening things. Wanting to reduce clutter, I think the bench grinder should be disposed of. *band file: Maybe you know it by another name? This is it: https://www.dewalt.ca/en-ca/product/dcm200e1/dewalt-20v-max-xr-18-bandfile-kit
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Use it a while before you decide. I have the same kind of accessory that fits one of my angle grinders- - - - -even with a speed control attached, it goes through belts in a big hurry, and there are still jobs my three bench grinders do best. They're set up for different jobs- - - - -wire wheel buffing, metal polishing with muslin and hard felt wheels, grinding high speed steel and carbide machine tool bits, etc. Jerry
| | | | | Joined: Apr 2016 Posts: 1,037 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,037 | I have pretty much every grinder and sander there is including at least 4 bench grinders with different wheels on them. My bench grinders get the most use.
| | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | I'd keep the bench grinder too. I have one that needs a new wheel, as the original one is worn down from use. I have three angle grinders as well, and a small sanding belt style knife sharpener.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2004 Posts: 2,401 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,401 | I just added two more to my shop my son was getting rid of. They’ll all have their special purpose.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2018 Posts: 267 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 267 | I find it hard to believe that the bench grinder isn’t the most used tool/machine in any shop. I have several. I don’t have one on a pedestal, but I plan to make one. Maybe the pedestal one takes up too much room, floor space….. I have a “ belt file”. It eats belts. But, each to their own.
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I've made grinder pedestals from discarded flywheels. Remove the ring gear to prevent floor damage as it's rolled around the shop, and add a length of pipe and a piece of steel plate to attach the grinder. Then position the grinder near the work that needs to be done. Jerry
