Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
10 members (Jay R, Gdads51, baldeagle, greenie-reddy, Wayne67vert, 68ironhead, 3B, JW51, walter74, 1 invisible), 51 guests, and 3 robots.
Topics128,004
Posts1,055,247
Members48,418
#1610715 09/03/2026 2:24 PM
Looking for two 235 push rods with solid lifters.
Crusty Old Sarge
Crusty Old Sarge
'What year is the engine? I have a set of 216 push rods but will need to measure their length.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Here's the listing for pushrods from the Master Parts Catalog. Looks like the 216 pushrods are slightly shorter. That's probably because the 235's crank centerline to block deck height is greater than the 216.
I've seen several examples of people using 216 pushrods in a 235 engine by putting the adjuster screw locknuts on the underside of the rocker arms. There's approximately 1/8" difference in deck height between a 216 and a 235.
What push rods set can I use as an alternative.
I’ve done research and the closest are 10.444” long.
Texas - You might reach out to "Rusty Heaps" through his Truck Parts for Sale ad.
He indicates in one of his reply posts that he has some 235 pushrods available. Perhaps they will fit your need? headscratch
Best of luck! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Ok I’ll do as you suggested. But was that post reply to my inquiry?
No - His post was started 08/14. I just happened to catch that he listed the 235 pushrods in his own 08/21 reply to the thread as I responded to him tonight about some items I'm hunting for.
Figured I'd just share the lead if it will help both of you out. wink
~ Dan
Thanks. Hooked on the link provided and someone this year asked him about 216 push rods. So I asked him about my needs.
I believe I saved the pushrods from a 235 I got that had a cracked block. I won't be back to my shop for several days to check but if you are not successful let me know. You can have them for the cost of shipping.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Thanks Kent. I’ll wait to hear from you. I’m not in hurry.
Crusty Old Sarge
Crusty Old Sarge
I measured the push rods I have, they are 11 3/8". Sorry.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Texas - A bit more checking in several Chevy Master Parts Books indicates your 1955 235 pushrod (one of those in Kevin's screenshot above) should be GM# 3836261. That number is listed with various length measurements including 10-37/64", 10-5/8" and 10-3/4" depending on which year the Chevy Master Parts Book was published.
Converting from fractional to decimal length indicates those would be 10.578125", 10.625" and 10.75" respectively.
The Filling Station lists their AF-540 GM# 3836261 Equivalent Pushrod as "Overall length is 10-37/64"." for your 1955 235 application.
'Should be just what you need, considering your pushrods measured 10.6" overall length seen above, as that slight difference in length of these is easily taken up by the rocker arm adjuster screw assembly.
Hope this helps you get what you need. wink
~ Dan
TUTS 59 #1610900 09/06/2026 11:57 AM
Thanks anyway. Thanks for your diligence.
Gearhead, thanks for your research. In the meantime I found these rods, attached screen shots. I think these would work.
Texas - Yup, those will do the trick.
If you've ordered them, should we go ahead and mark this one as "Found"???
~ Dan
Texas,
Mine are 11 1/4", so they won't work for you. Sorry,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Thanks for effort. Looks like I’ve found a source for the rods. See attached
Jerry, I ordered the push rods. Go ahead and close my request. Thanks to all who provided help.
