1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1605654 06/14/2026 12:54 AM
Lots of us have encountered seized-up engines. Here's a Facebook video of some people who are working on an antique hit and miss engine with a badly stuck piston, and they have come up with a pretty clever way to persuade it to move. I think a similar rig could be made to mount a 10 ton porta-Power cylinder over stovebolt pistons, using the head bolt holes to anchor the push plate. Another setup could push on the bottoms of the connecting rods once the crankshaft is removed, using the main bearing studs as an anchor point.
www.facebook.com/reel/1558368472534667
How about a jack hammer?
Some years ago, I was fooling around with an antique lawn boy with a stuck piston. Wouldn’t budge.
Ended up stacking enough fittings together to adapt the spark plug hole to a grease fitting. Grease gun popped it right loose.
Heck of a mess to clean up, but I was surprised how well it worked.
1951 3100
Hydraulic pressure is a good way to move something, but how many grease cartridges did it take? eek
You were probably lucky that the valves were closed. Wouldn't work if the engine was stuck on either an intake or exhaust stroke.
Lawn Boy had a 2 stroke engine- - - - -no valves!
Yep! wink
1951 3100
If the hydraulic pressure is high enough I'm sure the head gasket would go poof before moving some really corroded in pistons.
