1 members (PullG),
40
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Lots of us have encountered seized-up engines. Here's a Facebook video of some people who are working on an antique hit and miss engine with a badly stuck piston, and they have come up with a pretty clever way to persuade it to move. I think a similar rig could be made to mount a 10 ton porta-Power cylinder over stovebolt pistons, using the head bolt holes to anchor the push plate. Another setup could push on the bottoms of the connecting rods once the crankshaft is removed, using the main bearing studs as an anchor point. www.facebook.com/reel/1558368472534667Jerry
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 |
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Some years ago, I was fooling around with an antique lawn boy with a stuck piston. Wouldn’t budge.
Ended up stacking enough fittings together to adapt the spark plug hole to a grease fitting. Grease gun popped it right loose.
Heck of a mess to clean up, but I was surprised how well it worked.
1951 3100
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | Some years ago, I was fooling around with an antique lawn boy with a stuck piston. Wouldn’t budge.
Heck of a mess to clean up, but I was surprised how well it worked. Hydraulic pressure is a good way to move something, but how many grease cartridges did it take?  You were probably lucky that the valves were closed. Wouldn't work if the engine was stuck on either an intake or exhaust stroke.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Lawn Boy had a 2 stroke engine- - - - -no valves!
| | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Yep!
1951 3100
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | If the hydraulic pressure is high enough I'm sure the head gasket would go poof before moving some really corroded in pistons.
