5 members (55shaker, Woodcmiami, Gib70, Phak1, 3B), 105 guests, and 1 robot.
Topics128,115
Posts1,056,626
Members48,450
Okay, I am sitting in my office on this Saturday morning, trying to make a game plan for my 1948 (that I thought to be a 1949).
First a short info about me and the truck. I am a farmer since I was born, my grandfather told me so when I was 4 or 5. I grew up in Germany and immigrated to Alberta, Canada in 1981, married a German girl in 1986 and we are still happily together, now with three sons that have their own families and we have three grandchildren, two boys & one girl.
My wife and I owned a processing company for 25 years and exported legumes (peas, beans, broad-beans etc.) and other seeds & food product's around the world, mostly Japan, Thailand, Malaysia and some to North Africa & Europe. We sold this business in 2021 and I am told that I am retired, but I refuse. I still farm a little, but slowly face this part in me out. It just gets to hard on my old bones.
We build a new farm site in 2010, with a house (this was designed by my wife), that was to be small, but with space for the boys when they come and room for this and that, that became a 4300 sq-ft home.
I build a 60'x80' steel frame workshop for me. Insulated, floor heat etc. that our oldest son now occupies for this car building & fixing shop. It has a lathe, end-mill, CNC plasma table, welding tables, powder coating ovens, TIG, MIG and stick welders etc. that my son uses for his work. So in 2021 we added a 60'x50' extension to the former. Spray-foamed, but not heated, with a 20'x30' wood=shop inside that has floor heat in it. This is now my area where I can go and do my stuff.
We call it the machine shop. My combine, field sprayer, tractors, skid-steer, Quad's and 1953 Chev pickup are in it now.
The 1953 I bought last fall 1953 CHEVY and he is now nearly done, so I am on to new deeds.
Here comes my 1948 1 ton now. I bought the truck in 2008 and he run at that time. we did some work to it in 2017 1948 (49) brake work.
The truck is outside, covered with snow and my plan is as follows:
1. clear space in my machine shop and start stripping the 48 down to the frame.
2. re-do the frame from ground up, cleaning all and re-paint all. Perhaps sand-blast & powder-coat axles & frame so it is good for many years.
3. The current engine is done, kaputt, but I got a shop rebuild 216 that I bought from a very rebuttable company that has rebuild V8 Ford & Chrysler pumping engines for us over the past 40 year with a CAd6,300 Work-order that the owner never picked-up and lost his deposit on. I bought the engine for CAD3,600 and he is still in his crate.
Other option would be a 236 (I think, but need to verify) Oldsmobile engine I have, but it needs a rebuild.
Re-build the transmission (four-on-the-floor), drive shaft etc.. Rebuild the axles, front & rear. Check the breaks over again.
4. Keep the body as is, but fix the interior up to be nice & usable with change-over from 6 volt to 12 volt.
5. re-do the box floor in oak, I have the tools to do so.
This truck will become my daily, local driver beside the 53.
This will be a slow process, because I still have lots 'on-the-go'.
More to follow,
Joerg
1948 GMC Model 9434 Frame rebuild outside
1948 GMC Model 9434 Frame rebuild inside for winter work.
~ NORTH OF 49TH
1953 Chevrolet 1314 1/2 ton rebuild
Follow along it the DITY Bay
Sounds like you have all the tools and experience required to tackle this project. Your '53 looks great!
I am not sure but the 4 speed may be a SM420 which is pretty straight forward to rebuild if it needs it, they are pretty robust.
Looking at your post about brake drums it is not clear which rear axle you have. I am guess a 1 ton would have the Eaton HO, probably with a 4.56 ratio although I believe some had a 5. something ratio. There is a lot if information about converting them to a 4.10 ratio but those are getting very hard to find.
1949/50 3600 Project
Follow in Project Journals
Former Workshop Owner
Hello Joerg, thanks for sharing your story. I’m looking forward to following your 48/49 build.
Your ‘53 looks awesome.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
A quick update.
It is still too lousy to get the pickup in to the shop, but I looked through the supporting material I have for this truck.
The truck was bought in Coaldale, Alberta in 2008. The key-chain has a 1976 War Amps of Canada Tag # 118939 and a coal=miners tag like a star with ‘40’ stamped. (picture)
Contacted War Amps, waiting for reply. Found tag in the truck from Enerson Motors Ltd. Pontiac – Buick – GMC Lethbridge, Alta. Lic. No GMC 1 TON Handwritten: E. Anderson, Barnwell
No papers in the clove box, but lots of mouse nests (juck) big_eek big_eek
1948 GMC 1 TON PICKUP KEY-CHAIN
~ NORTH OF 49TH
Feb. 22nd 2025
The cold is over (for now yahoo) and I moved the truck in my shop, but first a few pictures outside.
48 STILL OUTSIDE
~ NORTH OF 49TH
Now inside
48 INSIDE
~ NORTH OF 49TH
And outside details
OUTSIDE DETAILS
~ NORTH OF 49TH
That truck is in pretty nice shape, sheetmetal-wise, except somebody clearly didn't like running boards and beat them up a bit. That right rear fender looks a little ugly, and someone attempted to fix it with bondo at some point in it's history. Could be pretty easily fixed if you're so inclined, but looks usable as is. The overall Patina is pretty nice.
Best of luck with your build. thumbs_up
I feel the truck is in general good condition, when compared to others I have seen.
Some damage to fenders, right running board, passenger door strikes too tight and the inside will be shown once I start cleaning the mouse-mess out.
Initially, I was going to do a total frame rebuild and this is still my goal. stripping everything off and sand-blast the frame & axles, than bring all to spec. with new King Pin, bushings etc.
Initially, I also thought to keep the body with the patina it has now, but my automotive son things 'why not paint it all proper since it is all going to be apart anyway. I am getting to like the idea, cause than the baby is ready for a long time to go.
~ NORTH OF 49TH
FIRST NOW - the ugly clean-up job.
I made an agreement with my wife that I split my (working) time to 1/2 for her bucket list and 1/2 for mine.
Will see how that will go.
~ NORTH OF 49TH
Some motor bay pictures
JUST SOME PICTURES FROM THE ENGINE BAY
~ NORTH OF 49TH
LOL! Good luck with that. I'm going to bet her bucket list will get top priority. At least in her mind. wink
What is the light on the front driver side fender below the parking lights?
1950 Chevrolet 3100 (Ol' Roy)
Otto - If you zoom in on the pic it looks like a surface mounted reflector instead of a light.
~ Dan
1951 Chevy 3 window 3100
Otto, this light?
If so, no clue, never actually noticed it!
THIS LIGHT?
~ NORTH OF 49TH
Otto, this light?
Yes. That's weird that there isn't one on the other side.
Maybe so. Why would a reflector be needed there? And why not put one on the other side?
I must go and have a look, you guys are worth than my son for chasing me around
~ NORTH OF 49TH
Haha!
Authorized Pest
Authorized Pest
Joerg, sorry I missed this in the DITY! Farm trucks and farmers usually jump out for us here at HQ. What a great project for your *retirement* and to share with your family. Looking forward to see your progress. (Stay warm! wink )
~ Peggy M
1949 Chevrolet 3804
Yes, it is a reflector and yes why? Why only on the left side (close to road center) and not both? This will probably stay a mystery forever.
Than the next question(s): remove it and fill the holes before we paint? Put a second on the right side and a new-one on the left (it's cracked) or, for curiosity sake keep 'as is' for everyone to ask me later "why".
~ NORTH OF 49TH
Sorry Joerg dang Wasn't meaning for you to go jump up and figure out what it is. I think all our trucks have at least one "owner add on" hahaha!!! I know mine has lots of them. wink Many with little or no explanation or understanding as to why??? headscratch
It's a great looking truck!!! thumbs_up
~ Dan
If you're going to clean it up and paint it anyway, I'd get rid of it. But it's your truck, not mine.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Even if I were going to leave the truck in its current unrestored condition, I'd remove the reflector and not worry about the screw holes.
I am just posting a few informational pictures here and will go to the relevant sections in this forum for more detailed discussions. I hope this is okay & correct.
48GMC DRIVETRAIN
~ NORTH OF 49TH
Post away Joerg! We can enjoy and share in your trucks early stage looks a you get ready to tackle your project. smile I think we can try and keep the "commentary" and "pestering questions" to a minimum. That way we can focus on helping you on things when you do have questions! thumbs_up
~ Dan
Box picture
I am removing the boards now and it gets me thinking about replacing it. Lots of dimensions, info etc. is in the BOX forum, but I can get a oak floor if I build it myself for less what I could buy a ready pine floor for. Any thoughts?
BOX PICTURE
~ NORTH OF 49TH
Hi Joerg, if it were my truck I would definitely go with oak instead of pine for the box. If you can find white oak, go with that. It’s much harder than red and will outlast you. If you can’t find white oak, red oak would be my second choice. It isn’t hard to mill the bed planks to fit your wear strips. Just take one of the metal strips and hold it against a plank end to draw the profiles you need to cut so the wear strips lay a little proud of your bed planks.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
That is my thought, too.
Thanks Paul
~ NORTH OF 49TH
Just a brief update.
The floor is still not out, just too many other things to do (ha-ha, my wife's bucket list grin ).
BUT the cab is coming along with a serious clean up.
The doors are off, roll-down windows have been removed, the bench seat is out and I am ready to remove the windshields and rear window.
I guess I will put all this to the side for later and make my decision if all new glass or re-use the good old pieces. New seals for sure.
Cab work in the 'INTERIORS" section
CAB WORK
~ NORTH OF 49TH
Alright. the sun is shining and I am on my 48 project again.
The old floor boards are out!
I was in the silly hope to 'just' undo the old bed bolts, but that didn't come as hoped, so I used the old fashioned brute force. Starting with the center board, halving it with the good-old Milwaukee skill saw and levering it out. Tricky were the front carriage bolts, but with some patience and wiggling I got all done.
CLEANED OUT BED
OLD BED HOLD-DOWN STRIPS
AND THE MESS FOR THE LANDFILL
~ NORTH OF 49TH
I still don't know how to write anything after the pictures in the same message, but it will come.
NEXT will be the running boards, rear fenders and the dissection of the box for straightening, fixing and sand blasting (or old-fashioned sanding) followed by priming.
BTW, I am impressed of the condition the old metal is in, must be our dry weather, were rust is not as aggressive as having 30-40" of rain and 80% humidity. Semi-dessert has its charm.
Stay tuned
~ NORTH OF 49TH
Authorized Pest
Authorized Pest
It's fine that you have a post that goes with the images ... that make sense to me! I really like that you have your image explanations in ALL CAPS. Makes it easy to read. thumbs_up
~ Peggy M
1949 Chevrolet 3804
Well, one little step at the time.
Left side running board is off and the fender. See what showed-up, the real old color. I think this will be what the horse will be painted with.
FENDER OFF AND THE TRUE COLOR SHOWING
SOME RUSTY SPOTS, BUT NOT TOO BAD
~ NORTH OF 49TH
Hello, a brief in-between-doing-anything report.
I did some work on the front end (fenders, bumper, radiator out etc.) but time is short right now to work on this right now, but I thought of something.
The engine in this truck will come out and definitely needs major work, but! I have a 261 engine that is on a stand and I will look it over. It seems rebuild because it is clean and first appearances are promising. Anything that speaks against the 261 to go into this truck with the four speed transmission, after the frame & body work is done?
~ NORTH OF 49TH
Impressive debris pile. I did a boat deck project that started off like that once. 😂
1950 3100w/63K
#1589031 10/05/2025 6:49 PM
Hello All,
I thought I give you a little update about my project.
Well, nothing has happened over the past month.
I was busy finishing my last harvest as a farmer. I pushed retirement away for six years, but everyone around me said 'its time to let go' and so I did. The land is rented out and our equipment is sold in the next twelve month.
My own suspension is not working to great. My left hip is done, finished, kaput and I will take two month off to get a titanium joint installed. Next year I hope I get a left knee fix-up here in our country.
Anyway, on top of all that, we had to clean our machine shop out, meaning removing the collection of stuff from 15 years (only, luckily). My hardworking, oldest son took all the fiberglass insulation out, 4" in the walls and 6' in the roof and we have a fellow spray foaming it to get it airtight. The shop has floor heat, but we could keep the heat in at cold winter days with -35 to -40°C. So, we spend some time and money and get it fixed.
Anyone ever builds a shop, wood or steel, do it right at the start and get it spray foam insulated. Its costly, but it works! We added 50' to our 60'x80' steel building without floor heat and had it spray foamed with 3" for the roof and 2" in the walls and this building stays around freezing even at -35 to -40°C.
So, the 1948 GMC has to wait a little longer, but he won't mind, I know.
Happy wrenching to you all,
Joerg
Last edited by Gdads51; 10/06/2025 2:28 AM. Reason: edit to merge with Dity thread where it belongs
~ NORTH OF 49TH
U
U Offline
My gosh - we might get a couple -degree days here in Utah, but nothing like you up north. It's nice to have a heated work space.
~ John in Utah
Here We Go
Follow in his DITY Bay
Hello Fellows,
I have been very quiet, more likely totally out for eight month.
One new hip, right upper suspension, done in Germany for CAD15,000 about. I could luckily stay with my mother-in-law and my wife was my driver. Enjoyed good food, beer and Christmas Markets. I have to say that the German system has the physio worked-out to near perfection. This is under German Health Insurance covered and is mandatory if you are insured under a German health plan. I could buy it for CAD3000 about (included in the total cost) and it was for 3 weeks, 5 days full program with paper trail! I feel it helped me a lot. Back to Alberta mid December and a call to my doctor revealed a open spot for my left knee in late January. One doesn't give a spot like that away and I didn't, so on Jan. 29th I had a partial knee replacement (left lower suspension) in our local hospital and all is good now after five month. After care is only there if you pay for it your self, but not as involving as with the hip job. 'I learned a lot!'
I have been busy with physio, equipment sales and gardening. My movements are still improving and give it two more month and I should be back to normal. My old 48 GMC sits as is sat when I left him in October. One seed drill and my combine still fills my chop, but I should be back at the rebuild next week or the week after.
I will keep you posted!
~ NORTH OF 49TH
Authorized Pest
Authorized Pest
Joerg. That's a lot going on with you. Glad you gave an update. Hope you'll be moving around better and better. When you get to your "48, I'm sure we'll hear from you.
wink
~ Peggy M
1949 Chevrolet 3804
Moderated by  J Lucas
