Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (55shaker, Forty9, baldeagle, NJC, cmayna), 41 guests, and 3 robots.
Topics128,005
Posts1,055,263
Members48,418
#1601641 04/11/2026 5:23 PM
I am needing to R&R the 216 in a 1946 1/2 ton
Not seeing much clearance for the cherry picker
What is the best way to pull the engine with picker ?
Or not possible without a A frame ?
52-Mobil #1601643 04/11/2026 5:37 PM
I built an engine leveler out of an old trailer tongue jack that bolts directly to the valve cover studs on a 216. With a shortened chain on the cherry picker, I don't even need to remove the hood on my '51. But I did remove the front clip.
klhansen #1601645 04/11/2026 5:45 PM
Thanks trying to find out if I have to use a A Frame
Not wanting to remove front clips
52-Mobil #1601648 04/11/2026 5:53 PM
Run your cherry picker up to it's highest point and measure that and the engine height to see if it'll be high enough with the rigging to clear the fender (radiator is even higher.) If you have a couple of rollers to move the truck, you could remove the front wheels to get another 6-9 inches by lowering the front.
The front clip removal wasn't a hard thing on my AD. Two nuts at the radiator support, the two radiator support rods at the firewheel, and 4 or 5 fender bolts on each side. Your 46 should be similar. Here's how I picked the front clip.
52-Mobil #1601652 04/11/2026 7:27 PM
I’m all for pulling the front clip, it’s not necessary to remove the hood. I have always done it that way. It makes everything so much easier. You and an assistant can do it in an afternoon.
I invest my money in precious metals, mostly rust!
52-Mobil #1602585 04/25/2026 7:23 PM
I just pulled the front bumper, grill, and radiator support to pull my engine and reinstall a new one. Fenders moved just a little if you leaned on them but no real issue there. Did not pull the hood and I used a cheapo Harbor Freight cherry picker with a load equalizer to get the engine out. It was close but I took the engine out by myself and did not hit anything during the process. Had help on the install.
Deegs
1953 3100
52-Mobil #1602586 04/25/2026 7:53 PM
52-Mobil,
I did an engine swap about a year ago on my 46 Chevy 3/4 ton. My son and I did remove the front clip, wasn't that big of a job to do so. Makes it so much easier to swap engines or just removing it for a rebuild. Also, made it much easier to work on the front if needed. I did the shocks and put in new front leaf springs at that time.
Make your life easier and remove the clip - just my 2 cents worth.
Tom
