Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (GMCJammer51, Bill Hanlon, 3B), 58 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1601910 04/15/2026 9:42 PM
1947 chevy 3100
My truck needs some attention to make it steer better. The frontend probably needs rebuilding and I am looking for some directions on the best route to take. The steering wheel seems to be out of sink when turning such that turning left requires less steering wheel movement than turning right. Thanks to anyone who replies. ray durham
bucktruck #1601912 04/15/2026 10:23 PM
Ray - There are way too many different components that make up your front suspension and steering to be able to easily answer your first question about the "best route to take". Everything from wheels, tires, springs, king pins, tie rod ends, drag link, steering gear and even front wheel bearings need to be inspected and confirmed on their condition, adjustment and lubrication (as applicable). If I were you, I would plan to go through each and every one of these items to help identify what may be the cause of your steering issues, addressing issues or at a minimum eliminating components as possible culprits, one at a time. It just makes sense to also clean and properly lube everything as you go through them so you don't have to try to remember what you need to go back to for that step if repair/replacement isn't called for.
If you haven't already, I would recommend you get out your shop manual and read through Section 3 - Front Suspension and Section 9 - Steering to learn all you can about what makes them up, how they function and how to adjust/repair/replace as needed. If you don't have a Shop Manual, below are links to the sections noted from an on-line copy of the 1948-51 Chevy Truck Shop Manual (which will be virtually the same for your '47) that you can access and read/study to your hearts content.
Section 3 - Front Suspension 1948-51 Chevrolet Truck Shop Manual
Sction 9 - Steering 1948-51 Chevrolet Truck shop Manual
Getting familiar with all the bits and pieces that make up these systems will help you when actully putting hands/tools to them.
PS - Once you start doing actual checks, if you nee help on a specific item (like king pins, tie rod ends, etc.) than ask specific questions and folks will try to offer the best info they can. wink
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1601916 04/15/2026 11:31 PM
Thank you. I do have the service manual. I was thinking someone who has already experienced this could maybe list in order the things they checked/replaced.
Thanks again, ray durham
bucktruck #1601954 04/16/2026 2:10 PM
J Online: Content
If it was mine, I would start with the tie-rods and drag-link ends. Remove them for a proper cleaning and inspection. All four ends are spring loaded and adjustable. The balls need to be round, so check that and the stems for any wear.
Next I would look at the king pins and wheel bearings. King pins require quit a bit of work and can be really tight or really loose coming out.
Wheel bearings need cleaned, inspected, greased and properly adjusted. Ball bearings require a different adjustment than taper bearings, so read the manual carefully.
Steering box would be the last item to clean and adjust, no need to adjust it when the other parts are worn. Yours likely has the steering wheel mounted off center causing the more to one side turning radius.
On a side note, my '37 always had a the steering wheel off center so I had an adjustable drag link made. The steering gear box needs to be dead center, if not it will have a loose feel to the steering. I don't no why my was off, never could figure out what was wrong.
Steering boxes are easy to rebuild build and adjust with the online manual as a guide. It to should be removed for a proper cleaning and inspection.
Last on my list would be spring bushings and shackles.
Tires need to be good soft rubber, old tires never drive right or non-radials. Radial tires don't follow the grooves like bias tires will.
With everything properly adjusted it will drive just as good as truck on the road.
bucktruck #1601960 04/16/2026 3:39 PM
For my truck the first thing I did after I got my 46 into my shop after a 3 hr drive from purchase was lift the front end and did a visual assessment, grab each tie rod/ drag link and see any movement, look at the spring end pivots and shackle position/ angle and see if wear is visible. Grab each wheel and try to rock it top to bottom.
Have a person turn the steering wheel while you observe the pitman arm movement to assess slack in the steering box,
Wheels on the ground have someone turn steering wheel to if see any linkages have strange movements.
Likely much will become obvious without jumping into any one thing. On my truck it was almost scary…..it was ALL worn out.
Good news it’s it is not that hard to correct any/all of these issues, and parts are available.
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
