10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I scored a nice 60 gallon 2 cylinder Quincy compressor off Craigslist for $250. It was legit- the seller is an industrial compressor dealer and he was upgrading their back shop. It came with a spare head and oil pump- this thing is like an automotive motor. It has an actual oil pump, poppet valves, unloader system, and a Baldor motor. You can either leave the compressor motor running constantly and use the unloader to regulate pressure, or use the tank switch.
Its a horizontal unit, weighs about 400 pounds. Its going to live in the attic space of my shop if I can figure out how to hoist it up there without killing someone.
Audios to my 30 gallon Coleman, how I hated ye.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Nice SCORE! Now you can keep the neighbors up late. :rolleyes:
Before you put that in the attic, check and make sure the ceiling joist will hold. That's a load.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you now have what is considered by most to be the best. Nice catch. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's not quite big enough to run a big blaster, but it keeps up with my 12 cfm HVLP gun no problem. I set it up in a corner of my shop for now next to the 240V outlet. It has a slow leak in the water drain valve, but that will be easy to fix. It sounds nice too, a nice soothing thub thub.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You know I have been thinking of relocating, Do either one of you guys have a outside connection? I have plenty of hose. Mike | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I got a Champion 5 hp 2 stage commwecial, I can run my cabinet all day and never run low. What I like is that it has an automatic water drain after the compressor stops. 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Joe Your too nice, Now we all know your price.I can always be talked in to BBQ too. | | |
