5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1596350 01/20/2026 3:36 PM
I was going through my pictures I have collected over the years and found this one, anyone know anything about factory shrouds? Looks like a '37 truck.
Joe H #1596352 01/20/2026 3:48 PM
I can't answer your question but it could very likely be homemade.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Joe H #1596359 01/20/2026 4:21 PM
Joe - According to a 1929-46 Chevrolet Master Parts Price List it was available for 1937 & 1938 3/4 ton and above trucks equipped with the heavy duty (3" thick) core radiators. There were ones also available for earlier and later trucks with the heavy duty radiator as listed. I'm sure it could probably be adapted to a 1/2 ton radiator too.
~ Dan
1951 Chevy 3 window 3100
Joe H #1596363 01/20/2026 4:47 PM
The bigger AD trucks had them and I think they will fit the pickups also .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Joe H #1596369 01/20/2026 5:47 PM
Looks like is helps use the top corners of the radiator, pretty neat setup.
Joe H #1597591 02/11/2026 7:03 PM
Joe: I have a '38 half ton pickup that I installed a shroud on. A few years ago someone on Ebay had three of them, I decided to buy one. They are for the thicker radiator as on a larger truck, so I cut a piece of a black sponge mat that you kneel on, the piece was about 1" X the width of the radiator (20" ?) and I used it to fill the space at the top of the shroud to the radiator. Glen
1938 half ton pickup
