0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#1596170 01/17/2026 5:29 PM
I just bought my first AD truck with battery under the passenger floor board. I would dearly love to relocate the battery. Of all the zillions of videos and photos of AD trucks on the road, I haven't seen one showing the battery on the firewall like the TF and newer. Is it possible to locate the battery behind the seat even with the gas tank, or does everyone keep it under the floor?
do a search for your year or several years and "move battery to engine bay". There are a few forums out there I like to change my google search to images tab and you can spot some easy that way.
he is a example with pictures
https://67-72chevytrucks.com/vboard/showthread.php?t=471303
LMC also offers a drop down battery box allowing you to move it anywhere on the frame with it under truck. granted you have to get down to get to it but it hides it nicely and you don't have to go inside to get to it
On your question about if there is room behind the seat with the gas tank, that would be a nope - sorry. You wouldn't want it back there anyway unless you plan to change the rigid seat back to something that allows for folding forward, and moving the gas tank elsewhere. wink
hcb3200 provides a good pointer towards ideas to match yours. smile
~ Dan
1951 Chevy 3 window 3100
I relocated my battery to the passenger side firewall similar to the installation shown in the link from Dan. I have a twinge of regret for cluttering up the engine bay , but it sure made life and battery maintenance easier.
back yard wrench turner
I also relocated the battery to the passenger side firewall. Much easier to maintain there.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Mine is under the truck with a cut off switch in the seat riser. It's easy to kill the battery every time I get out of the truck. With it right above the battery, the cables are short and it gave me a place to hook up direct to the battery cable for the electrical system. Use a maintenance free battery.
Mine is the same as Joe's. The cut off switch is in the battery to ground cable.
I am so use to the battery being under the floor (Stock). Based upon how often I need to disconnect the battery, I see no real reason to move it. It's pretty easy for me to lift the rubber floor matt and lift the battery cover. Already have a kill switch in place.
Craig
Me too. How often do you need to monkey with a battery? Under the floor is a pretty convenient place for it in my opinion. It's low enough to make it easy to reach and lift when necessary.
I keep a battery tender connected to the ground and (+) starter post when its not in use.
1950 Chevrolet 3100 (Ol' Roy)
I think my engine compartment is prettier w/o the battery in there. Really. Prettier. Less cluttered.
62401
You all beat me to it. My battery is still in the original location and I see no good reason to move it. Besides, its an Optima 6-volt. Other than needing to borrow it from time to time to run the Farmall Super A, I really haven't needed to do much at all under there in the 12 years I've now had the Optima. The negative lead popped off once but 20 seconds with the 9/16ths fixed that.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks for all the feedback. I find reason enough to access the battery often enough that a subterranean dive is not an option. I finally found a Youtube video that demonstrates exactly how I should do it.
Last edited by John Milliman; 02/01/2026 9:20 PM. Reason: No embedded YT vids... costs too much on our end
John--I can certainly understand the need to avoid the ridiculous fees associated with some of this digital on-line life we have chosen to lead. When composing that message I intended to just copy and paste the URL, but somehow the whole video appeared. Thanks for the edit
62401
No worries!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
