2 members (Jeff Ogden, cmayna),
108
Mod | | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 2 Moderated | | Moderated Joined: Sep 2020 Posts: 2 | I have a 1936 1/2 ton pickup that has the engine removed. I want to install a replacement 1936 207 ci engine. do I need to remove the damper pulley and timing gear cover to bolt the engine to the front mounts? when I removed the original engine I was able to remove 1 bolt from the front mount but could not remove the 2nd bolt. I am assuming I will have to remove that damper pulley and timing gear cover to be able to fish the bolt out | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | I think I can help you. Feel free to call or text me at 573 864 6539. I have a 1936 1-1/2 ton truck.
Mike Russell Columbia, MO
