| | | Forums66 Topics128,163 Posts1,056,964 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 27 | I was rebuilding the rear mounts for1951 3100 cab. I was checking to see if Grade 5 bolts are okay to use. Also does anyone know the length of the bolts used on the rear cab mounts the old ones are gone. | | | | | Joined: Sep 2009 Posts: 5,983 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,983 | Miller - The 1947-54 FAM says those bolts securing the rear cab mount to the frame and cab floor brace are common hex head bolts, GM# 120233. From what I could track down, the dimensions for those bolts are 7/16-14 x1 1/8" bolts and should be accompanied with 7/16" split lock washers. I couldn't find a designated bolt grade, but think at a minimum a Grade 5 is needed. Just to be on the safe side a Grade 8 wouldn't hurt. Hope this is helpful.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | I added seat/lap belts in my 57 3200 and grade 8 were required. It would seem silly to attach a grade 8 seatbelt to a grade 5 cab!  1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Jul 2021 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 27 | Thanks for the info after looking at the 7/16 -14 were to big had to go with 3/8-16 to fit right. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | Which bolts are you referring to? The ones which go through the rubber or the ones which go through the frame?
